Question about Samsung Refrigerators
Xflow fan stopped working
I have a Samsung Cooltech super xflow refrigerator, the xflow fan that spins around at the back of the fridge (inside) that distributes the cool flow has stopped spinning and the little fan that controls it has stopped working (no noise from it at all). My question is, how do I change it or does anyone have a service manual on how to replace it?
2 Suggested Answers
SOURCE: Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
Posted on Jun 01, 2008
Hi! I've got a problem with My Samsung cooltech plus fridge! Every 3min it rings 4 times nearly and the lamp inside the fridge doesn't work !! And the temperature is not low only in the fridge
It's probably telling you that a door is open (which would also explain why it's not getting cold, and probably the light just burnt out from being on for a long time). Check for things blocking the door from closing all the way, and look around the part where the door seals shut against the main part of the fridge.
Aug 03, 2016 | Samsung Refrigerators
I have a Samsung Cooltech and the lower section of the freezer is not freezing as efficiently as the top section
Check for fan not working in freezer can be fan or it may have a dual switch that operates fan and light
Mar 24, 2015 | Samsung Refrigerators
My Samsung Cooltech plus fridge's temperature keeps on skipping back to 9 degrees celcius. Freezer is working fine, what can the problem be?
Every time I select my fridge and freezer temperature from -16 and 3 degrees C respectively it keeps on going back to 20 and 18 degree C. Please assist.
Mar 11, 2011 | Samsung CoolTech Plus / Basic Bottom Mount...
Does the airflow keep rotating or does it stop in between? My samsung cooltech srv39 works fine but the airflow system does not move since last couple of days. How to fix this?
By airflow do you mean the fan. There is a condenser fan underneath at the back of the unit and there is an evaporator fan inside the freezer behind the rear cover. Both of them should be running anytime the compressor runs. You can see how to test the fan here- http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | Refrigerators
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung SR423NXB
hello andrea,
could you give more details ?...is the compressor running? what do you observe in your unit? are there error codes?. are there fans which are not running?
tnx 4 using fixya,
drcool
Sep 20, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Jul 19, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
hi
yours
sandesh
May 15, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Assistance required
A thermostat would have nothing to do with this problem. Condensation occurs when warm air moves into a cold place. Check door gaskets or any possible way that warm air is getting into the cabinet.
Nov 07, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
48 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
