Question about Canon Powershot SD450 / IXUS 55 Digital Camera
SD450 is won't turn on, and is stuck with the lens extended
My canon just suddenly stopped working, while the lens was extended. I tried recharging the battery, and reinserting, and nothing happened. There's a chance that maybe a bit of sand or dust got into the camera, and I wonder if there's any way that I can clean it out, or fix it myself? Thanks!
  • Anonymous Sep 28, 2008
    I dropped my SD450 canon powershot in the sand, and it hasn't worked since. Sometimes I can take pictures, but sometimes they turn out blurrier than normal. my lense is stuck extended, and it will turn on, only for the canon homescreen to show up... then the camera turns off automatically...
    Master:
  • 383 Answers
Usually dust particles or the slight dislocation of gears..... one of the simplest solution is when you turn the camera on try rotating the lens clockwise very very softly ..... dont force it or it will get damaged....... 90% times it works
Posted on Oct 12, 2008
Casio exilim EX-S10 wont turn on and lens stuck out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here is a video summary of the steps:
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
What can i do if my ixus 55 has been dropped on the ground and it can't work? i mean, i accidentally dropped it on the ground and after that, it could not be turned on again. i tried every thing. how can i...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 18, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
The zoom lens will not retract when you turn it off, subsequently an error message (E18) apprears when you turn it on. the camara store wants $150 to fix it......is this something I can fix myself? Thanks...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 02, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Error E18, the zoom is blocked
Hi
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
There are six screws holding the metal frame of the camera body together, two on each side, and two on the bottom. Remove all screws, pop the strap-hook plate (sorry, probably not the most technical term there), then gently lift the front plate off by pulling up from the bottom, and remove the back plate in the same fashion. These should come off relatively easily. This is what the camera should look like as you remove the plates:
img-5340-thumb.jpg?w=324&h=217
  1. Now, looking from the top of the camera, you should see a small motor on the left side, as shown below (it’s beneath the cable with a “22” written on it):
    img-5346-thumb.jpg?w=324&h=217
  2. Take your screwdriver (or another small instrument) and gently try to rotate the plastic piece attached to the motor on the left side, as shown below:
    img-5359-thumb.jpg?w=324&h=217
  3. At this point, try placing the battery back in the camera (if you have removed it), turn the camera to one of the capture modes, and press the power button. If all went well, your lens should now be able to extend and retract properly.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E18 appears on the camera and the lens won't close
Mar 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E18-lens stuck out-not fully out-won't budgein or out any further
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. As you've dropped it, you might need to start with Fix #7:
Feb 06, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
