Question about Dryers
The power is out because of Hurricane Gustav. I have a 6500 watt portable generator and would like to use our clothes dryer which has a 220 volt requirement. Is that possible, and is there a special extension cord I could run from the generator (located outside) into the house to connect to the electric dryer? There are several outlets on the generator and one says 240 volts. ?? Rusty
    Scholar:
  • 141 Answers
Dryers require a 40A circuit breaker to handle the current. According to Ohms Law: Watts = Volts * Amps. Therefore, you require a power capacity of 220V * 40A in order to safely run the dryer, which is 8800 Watts. This means your generator does not have enough capacity to run the dryer. If we consider the full power of your generator at 6500 Watts, this only allows for 29.5A, which is not enough to run your dryer.
If it WAS possible, you would need to ensure that you ran a 30A heavy extension cord with the correct 220V plugs and receptacles on the end. This would require at least 10gauge 3-conductor wire, which is quite expensive.
However, that point is moot, since your generator does not have the capacity to run your dryer. You could try it, but I rather suspect that the dryer will trip the 30A breaker on the genset circuit. If you do try it, make sure you run a 10-gauge, 30A extension cord or you could have a fire.
Posted on Sep 06, 2008
What means P50 ryobi generator 5500
Ryobi 5,500-Watt Gasoline Powered Portable Generator
Watts = E (voltage) * I (current) The manual will give 120 vac load limit as well as 220 volt load limit.
https://www.homedepot.com/catalog/pdfimages/39/39ebfc9d-52e6-4acb-8205-fa94c1347e04.pdf
Nov 30, 2017 | Electrical Supplies
Troubleshooting onan repair
You have voltage,but not Amps.Voltage plus Amps = Power
Charge the Battery .
No amps, low power,its why makes only clicking sounds.
Sep 01, 2014 | Watts Onan Portable Generator - 5000 ,...
Is 147 Amperage ton much at rec
I don't understand your question. Are you asking if 147 VOLTS is too much at the receptacle? If so, yes - that's too much. Are you asking if 147 amps is too much to expect from your generator? If so, yes, that's far too much.
Jul 18, 2014 | Watts Onan Portable Generator - 5000 ,...
GE Generator 10kw model #040448. TRANSFER SWITCH FAULT message being displayed. Generator works fine. Generator output load voltage = 233V.
This generator has a built in transfer switch. If you do not have an external source of 240 volts going in to the unit (utility power), the transfer switch will show a fault or "abnormal" reading. If you do have utility power going in to the transfer switch, and the generator is on then you have a faulty transfer switch. It is time to warranty or get a replacement switch.
Sep 09, 2013 | Watts Onan Portable Generator - 5000 ,...
Just need to no witch one wire goes where Putin it back to gather it's a 6500 watt with two two tweenty plugs on one side of the round end and two one tens on other side
take the wires, and read them with a multi meter. checking the voltage of each line. the ones with no voltage will be your neutral wires and the ones that read 110 will go in each side of your 220 plugs, or two will go in one plug only with a jumper to the others and the bottom hole will be your neutral. you can jump one leg off the 220 plug for your 110 side and the other 2 wires from your 110 can go to ground.
Aug 14, 2011 | Briggs & Stratton Briggs Stratton 6200...
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Where do the four wires coming out of the right side marked ac circuit breakers go
Hello
Is it a 220 volt generator? If so then the green is ground, the white is neutral and the other two are hot wires. Do you have more information?
John
Oct 19, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan 6500 male 120/240 plug
Northern Tool has a hundred plugs/recepticles. you need to know the amps and volts. just match them to the pictures. or email them a pic of what you need. they helped 3 of my customers with the issue. hope that helps...good luck...
May 28, 2009 | Watts Onan Portable Generator - 5000 ,...
Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Sep 18, 2008 | Electrical Supplies
Generator will not generate electricity.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Dryers Logo
100 people viewed this question
Top Dryers Experts
