When modem is conected through router computer not recognizing internet connection. with or without modem bridged
  • 320 Answers
Go to Control Panel -> Network connections make sure the Local Area connection is enable. if this working fine then replace you LAN card. LAN card is connected to the PCI slot of the motherboard. And install drivers for your LAN card. Thank you
Posted on Sep 06, 2008
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
The Internet LED is red when there is no Internet connection
Unplug router for a minute or so and re connect also check if the computer is even recognizing the router in control panel under network conections
Jul 09, 2012 | NETGEAR CONSUMER Netgear Dgn2200m Wireless...
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
When I plug my modem into the computer, the internet works fine. But when I plug the modem into the router and plug the router into the computer, it don't work no more. And I can't get on from my laptop...
>You need to set the modem to Bridged Mode first, then connect the router to the modem so that all configuration will now be controlled by the router.
>Ask your Internet Service Provider on how to set your modem to Bridged Mode.
Oct 23, 2010 | Linksys Wireless-G WRT54G Router
My computer is showing the conection but not letting me on the internet how can i fix it?it says conneted and says no internet access.
1) try turning off and restarting the modem and router.
2) if you are using a dsl connection check if the modem is in bridge mode with your isp.
if yes then
type click on start->run->cmd and press enter
in the black window type ipconfig
now note the default gateway and type the default gateway in the internet explorer Eg \\
check if the router is set to connection type as pppoe.
enter your usernaem and password and save the internet light will go on.
if the modem is not in bridge mode then try connecting you pc directly with the modem and check if the internet is working not not. if not contact your isp for settings.
if internet is working fine.
not connect your router to your modem and then your router to your computer.
check if the router is set to optain ip automatiicaly and save changes.
if you still face any issue let me know.
Jul 05, 2010 | Linksys Wireless-G Broadband Router
Your firmware may not support bridge mode, try installing dd-wrt from
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
Internet problem connection.....
your computer has been set up to be the PPPoE account holder for the modem. if you have a router, you will need to configure the router to login to the ISP account using the PPPoE information so that your router is the account holder for the modem, then you will be able attach multiple computers to the internet using the router.
Jun 21, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Ativa router
ok, fine....
Reset the Ativa router to factory defaults. This is normally accomplished by holding the reset button down for 10 seconds or more with power on for most routers.
Once you do that, you need to connect the computer directly to the motorola modem and configure it to be in "bridge mode".
Putting your modem into bridge mode means to bypass the router function and make it work as a simple modem. And, yes, if you do that then you must configure your wireless router to make the internet connection. If you don't want to do that, you can leave the modem as it is, I think the Ativa wireless router can still work even if your modem is still in PPPoE & you can still configure the router as an ethernet switch & wireless access point.
Now you can connect the router (after powering EVERYTHING down), turn on the modem, wait for steady connect, turn on the router, wait two minutes, boot the connected PC.
After you get a wired machine connected, you can enter the Ativa setup and configure the wireless security.
Open up IE or Firefox. On address bar, type in "" and click enter.
Ativa wireless setup should load up. On top right, there is a Log In button. If this is your first time login in, leave it blank and submit.
Check up on the following: a) Internet WAN > Connection Type > select Dynamic; b) Wireless > Channel and SSID > Disable ESSID Broadcast, also set wireless channel to AUTO; b) Wireless > Security > set up your security, you should know what to do.
Now for the most important thing. Click Firewall, and DISABLE IT!! By doing this, it said that you'll will be vulnerable to hacker etc...blah blah, but with security keys to access wireless and virus program/window firewall should be enough to make you stop worrying. Apply changes, then the thing restarts.
*** also leave MTU setting to 1454 & set it to auto connect; leave the DNS & MAC settings alone; also leave LAN settings as it is.
i would greatly appreciate if you could give me the modem's exact model no. (such as SB4200, 2100 etc.) and the router's as well....
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
