Question about Acer Aspire 5600 Series 5630-6951 Laptop
The screen turn white
While working if i move the screen slight it turns white please tell me what shoul i do
  • scallion2 Oct 10, 2008
    If I move my screen it turns white
My 1545 turns on then the screen slowly goes white but when i mess around with the screen pushing it moving it up and down will come back briefly says Graphics display stopped working
Please test using an external monitor first,this will exclude motherboard issues if the external display is normal.Nearly all screens turning white that I have observed is a screen fault requiring replacement.
Sep 03, 2014 | Dell Inspiron Computers & Internet
I broken my blackberry 8520 screen and i replaced it today but the screen is white and nothing will show up can you tell me how i can get it working again thanks
Hi, the problem you have is with the connection between the screen and the circuit board if you have fitted the screen yourself then the chances are its not fitted correctly or their is some muck blocking one of the connections, this is a common problem on all flip and slide phones as they have a thin ribbon that gets damaged and needs replacing and you get the problem your having.
its a connection problem you need to get the connections checked between the screen and the circuit board, try switching the phone on whilst you have the case off to make sure it works before you put it fully together as you might have to do it again.
if after checking the connections and they are fine then the chances are the screen is no good or you have a faulty connection on the circuit board.
the problem is to do with the signal from the screen to the circuit board, the phone is working as it gives you the white screen but the correct data is not getting to the screen and this is why it turns white.
have a go at checking the connections if you done it yourself you need to make sure it perfect and free from any muck they only need to be slightly out of line for the connection to be bad, with the case off switch the bb on and check you have the screen working before you put the case on as you can move the screen slightly with the case off.
if you did not replace the screen yourself then leave it to someone who has some idea of what they are doing.
Aug 17, 2010 | Cell Phones
I have an american standard tub and it constantly clogs. I used drane-o and it worked for a little bit but I think its the drain in the tub. How Can I tell if thats the problem?
Take screws out of plate on tub over flow and pull up trip lever. sometimes they move and need adjusting . It shoul dhave 2 bolts holding the plate on tub at overflow and work with it to remove trip lever assembly once out run some water down drain to let you know if that is th eproblem then you can adjust on trip lever assembly by moving the little barrel like plug near the handle a little will increase water flow out of tub once you put it back in you can adjust it out it back in with out bolting back turn water on and move lever to see if it drains any better.
They can be tricky but you can do it.
Mar 21, 2010 | American Standard 1583.470.020 Universal...
Samsung sgh-i607 got wet
mi blackjack got wet and it does turn on and it says that i have a text msg and that i have 3 missed calls buy the entire keyboard is not working,, what shoul i do?
Jul 08, 2009 | Samsung Blackjack SGH I607 Car Charger
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Screen is white and doesn't display area being photographed. Can take pictures.
1. Hold camera firmly in left hand.
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
Worked for me :)
// Maxim
May 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Screen is all white
Maybe LCD has broke.
Or LCD has failure.
Nov 16, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Acer Aspire 5600 Series 5630-6951 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
