Question about Panasonic CT-32D12D 32" TV
Audio outputs i have a panasonic 32" tv it is a few years old . i want to hook up a surround sound system. what do i use as an output?
  • 2,334 Answers
Click here to download the user's guide and go to page # 9 of the pdf file, the instructions on how to connect the audio to the surround sound or amplifier are there.
Posted on Sep 06, 2008
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
Trying to connect Surround sound system with 3 Other Components!?
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
Aug 31, 2007 | Panasonic SC-HT75 System
Th 37px70ba
Be sure the source(cable, satelite box) has sound output.Have you lost sound from all the inputs to the TV?(try hooking up a DVD player.
If these sources are OK then Most likely the Main PCB is the cause of audio failure, but could also possibly be the voltage source for your audio circuit & that comes from the Power Supply circuit. That's usually @ 12-15VDC.
Nov 24, 2013 | Panasonic Televison & Video
We have just bought an Akai 32 inch full hd tv (ak32fled) and are trying to hook it up to our surround sound system. We have hooked it up so that we can watch dvds through the tv, but there doesn't seem...
There should be audio out sockets at its rear side. Refer user manual for details about how to connect it with external audio output devices. If you feel any difficulty, contact the authorized dealer.
Oct 05, 2013 | Akai LCT3201TD 32 in. LCD Television
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
I bought a insignia plasma tv and a panasonic surround sound with blue ray. Both were open box and no manuel. I hooked up the surround sound and it works good with the blue ray. I can not get it to work...
Basically, you have to use the output audio from the TV to go to the receiver.
On the TV, there should be a red and white audio output jacks for left and right. Or, if the TV has it, the best audio output to use for surround sound is optical output. You'll have to buy a optical cable for this.
Sep 28, 2009 | Televison & Video
Can't find audio out on my 32" element to hook up my dvd surround sound system. i have a cable box and my dvd system hooked up to the tv. the surround sound works great from my dvd but there doesn't seem...
If there is it would be the "rca" cable that has a red and a white marking, and it would say "out" on it or "audio out" Some TV do not have an audio output so you maybe right.
Aug 12, 2009 | Element ELC-HS321 32 in. LCD TV
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
Panasonic CT-32D12D 32" TV Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
