Question about Samsung HT-DB120 System
DVD player not playing DVD's
My DVD player will play Music cd's but not DVD's, Do you think it could be the laser?
  • 2 more comments
  • wellerspur61 Oct 19, 2008
    cant load a dvd, tells me 'no disc, ' however I cant load a dvd laser cleaner as it tells me the same mssg !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! HELP PLEASE
  • deedub777 Jan 07, 2009
    This seems to be a running trait with this system. Replacement laser units are about 70 quid. I only paid £100 for the thing brand new - not happy :-(
  • Anonymous Jan 13, 2009
    my dvd
  • chris8719 Jan 13, 2009
    my dvd player has stoped working but still plays cd's y and how
    Novelist:
    Champion:
  • 277 Answers
Yes. The laser lens in your player is dirty or failing. To fix your problem, try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail stores.
Posted on Nov 30, 2005
    Problem Solver:
  • 6 Answers
Open the cabinet if you can,then using cotton buds clean lens with out any liquid cleaning....i hope you can fix it
Posted on Apr 25, 2007
The Iview 102dv player played a music dvd ok for the first 3 times. The player is about 2 months old. It gets stuck on the first song of the music dvd. If taken out, then it may play from the 2nd song...
Not an expert in DVD players, But it sounds like a scratched DVD or a weak laser. You could try buying and running a laser lens cleaner through it, as that will clean the laser and make it play better.
Also check if there is a firmware update for the DVD player.
May 30, 2011 | RJ Tech iVIEW-102DV DVD Player
It doesnt play dvd only music cd
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
May 02, 2011 | Televison & Video
Problem
first you most clean the laser with alcohol and try again or change the region code on your DVD player.......
Jun 13, 2010 | Coby DVD-215 DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
DVD player not reading dvd's
Check the link below to see how to clean the laser on a DVD player. If cleaning does no work, then the player will need servicing.
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Jerry G.
May 13, 2008 | GoVideo DV1030 DVD Player/VCR
Dvd player error
PS has no effect.. Most likely the laser is going bad in the DVD.. See if it will play a music CD* If it will play a music CD but not the DVD it is the Laser. Most of the Laser asm are made in china and don't last long.
Apr 05, 2008 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Jan 05, 2007 | Apex Digital PD-450 Portable DVD Player
Samsung HT-DB120 System Logo
499 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
