Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool Duet Washer is displaying a F70 error code, how do i fix it
  • 7 more comments
  • bmeeks2790 Sep 13, 2008
    I have the exact same model and today it started showing F70 error code. We have unplugged the washer for 30 mins several times and the error keeps coming back. Unit was purchased July 2, 2007.
  • hockeygalnc Nov 09, 2008
    My washer just started to do this tonight. Does anyone know how it can be fixed or does a technician have to come out to my house?
  • icdniner Dec 05, 2008
    Our machine will beep several times during a cycle without showing an error code. It eventually completes the cycle but we have no clue what the beeping is for. We have checked the debris filter and we use HE soap, what else could this error signal be?
  • Anonymous Dec 07, 2008
    My Dryer is displaying the F 70 code and not opperating
  • tcirello Mar 07, 2009
    My washer beeps in 3 times in a row, over and over.....no error code...does anyone know why?
  • Anonymous Mar 30, 2009
    my washer shows error code F75 and SOL or 5OL errors at start. Whe F75 shows it stay and cannot be cancelled or unlock the door.
  • Anonymous May 09, 2009
    F 70 with no function, no lights- how do you fix it
  • Anonymous May 23, 2009
    Our whirlpool washer is also continuously beeping in a 3 beat sequence throughout a wash. d-d-deet d-d-deet d-d-deet. There isn't any error code, but when it stops, it just has the number 8, and our controls are frozen on permanent press. After we start a load we can then change water temp and height and a few other options. Unplugging it does nothing.
  • george malarchik Sep 16, 2013
    F70 Code means that there is an issue between the MMC and Motor control, either can go bad and you get the same error, I just replaced the Microcomputer Machine Control on ours and it worked fine once, then started back into given the Code, I have read so many things about these machines I will never buy another Whirlpool machine. now I am sitting here scratching my head trying to figure out why it worked after I replaced a part now after two days of it sitting its not working and no one in the house used it, even ran a short heavy duty drop cord to another outlet still same thing.
We've owned a Whirlpool Duet Washer (WFW9200SQ00) for about 3 years. We started getting the F70 error code intermittently about 6 months ago and it seems to progressively be getting worse. Unplugging the unit for a few minutes resets the error, but it comes back about every 2nd or 3rd load causing my wife a lot of frustration and with 4 kids, our laundry was backing up. After reading several Forum's, I found the F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board. Before spending nearly $250 for a replacement board (http://www.helpfulparts.com/servlet/the-5733/8183196/Detail) with no guarantee that it would fix the problem, I decided to take the board out of the machine and inspect it. What I found is the connector for the communication (the connector with three blue wires) on this board is a very unreliable connector that uses the edge of the printed circuit board on one side of the connection instead of a real connector soldered to the board. In addition, the fit of this connector seems to loose to make a good connection. I noticed a little bit of corrosion on the board contacts which I cleaned with rubbing alcohol and a pencil eraser. After re-installing the cleaned board we've done several loads with (keeping my fingers crossed) no errors. I am still concerned about the reliability of this connection. Because of it's location, this board is subject to a fair amount of vibration and because of the loose fit I'm concerned that this issue will only come back over time. I've already decided that if the error comes back I will solder wires to the contacts on the board to provide a more robust connection. It's a shame that you can spend well over $1,000 on a top of the line washer, and in order to save $.10 Whirlpool decided to use a very poor connector in a critical area. It makes you wonder where else did they skimp to save a few pennies?!! Our next washer will not be a Whirlpool, and next time will not get a high end washer with all the bells and whistles.
Posted on Jan 03, 2010
  • Doug Tanner Oct 26, 2012
    Well to me it's sounds like they could be crooks making the connection like that so loose. Seems to me that many people are having this same problem which in turn helps Whirlpool out because that means people will be buying more parts! Or another washer but hopefully not from whirlpool...
Does it beeps 3 times and do nothing no other lights on?
Posted on Oct 09, 2008
I have the same error....and yes it does beep with no other lights on.....any fixes?
Posted on Oct 19, 2008
2 Suggested Answers
  • 198 Answers
SOURCE: Whirlpool Duet washer is displaying an error code
Most likely the main control board is defective. check connections between interface and main board before replacing.
Posted on May 18, 2010
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 70 error on my whirlpool duet washer
Hi, F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board which needs to be replaced.
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
3,143 people viewed this question
Dan Webster
Dan Webster
Sal De
