Question about JVC AV-27120 27" TV
On Timer light flashing on my TV
My JVC AV-27120 27" tv one day suddenly turned off... during Sportcenter no less and the "On Timer" light has been flashing ever since. The power button on the TV as well as the remote have no response. I changed the batts on the remote just in case and same effect. I've unplugged the TV for 4+ hours and plugged it back in, same effect. Can you please advise? Thanks so much.
  • schlitzschli Dec 18, 2008
    have the same problem. jvc timer flashing.
    fuse looks good.
  • Anonymous Mar 23, 2014
    After being away for 11 days, we found when we cam home that our TV would takes ages (anything up to a couple of hours) to turn the tv on with remote, then a very long time (up to a few hours) for picture to come up. We did have it plugged jnto a power board, took it out & plugged straight into power point, no difference. Could you please let us know if it can be fixed or will it be too expensive to repair? Many thanks, Heather
    Novelist:
    Champion:
  • 277 Answers
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Posted on Nov 30, 2005
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
On- timer light flashing no picture no sound.
hit the timer or program button on remote. see if that helps. your trying to get the picture up so you can turn the timer switch off. make sure tv is on. reply if you need more help
have a great day bama46 please rate
Aug 22, 2009 | JVC AV-32D502 32" TV
On timer light flashing
first you need to re soldered your tv, coz 50% problem of tv is lose connection, but be careful of short circuit,if nothing happen check the horizontal output transistor,
Oct 31, 2008 | JVC AV-20220 TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
TV will not stay on
HI DrRome:
Sorry , I would think that the vertical circuit has failed. you will have to take it to a repair shop.
Feb 22, 2008 | JVC AV-27230 27" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
JVC AV-27120 27" TV Logo
379 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
