Question about Compaq Evo N610C Notebook
After calibration I went into BIOS and calibrated my battery. It charged it, then discharged it as its supposed to do and then it is supposed to recharge it. Instead it brings me back to the desktop. Any idea how to fix it?
  • ERIC416 Nov 10, 2008
    help me cant get thru the log on winown screen@!
Tip
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | Computers & Internet
My battery is set up to charge to 80%. How to I change it to charge a 100%?
It possible that you battery needs to be calibrated. Here are some steps that may help resolve this issue:
  1. Connect the AC adapter and allow the battery to charge to 99% - 100% of capacity.
  2. Disconnect the AC adapter from the notebook PC.
  3. Click Start , enter power in the Search field, and then selectPower Options from the list.
  4. Select Create a power plan from the left sidebar.
  5. Click in the Plan name field and type Calibrator . Then, press Enter .
  6. Select Never for all topics in the On battery column.
  7. Click Create to accept the values and force the battery to consistently discharge.
  8. Allow the battery to discharge completely until the notebook PC shuts down.
    9. Connect the AC adapter and restart the notebook PC.
    10. After calibration, return to the Power Options dialog box (Step 3) and select your default power plan setting.
  9. After calibration, return to the Power Options dialog box (Step 3) and select your default power plan setting.
Jul 11, 2011 | Computers & Internet
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
I have compaq evo N610claptop, it works when plug power cable. battery also charging. but when i remove power cable computer shut down
You have to calibrate the battery.
Reboot press F10 go into the bios and look for battery calibration. Please note that it takes awhile
1 recharge
2 discharge
3 recharge
and it's done
Nov 24, 2010 | Compaq Evo N610C Notebook
The battery is fully charged and loses the charge within 15 minutes of being fully charged. Battery is 18 months old!!!!! Help
Simple fix turn on the puter on the logo screen press F10 to go into bios setup page scroll over to battery calibration on the tabs on top you will see HDD and Battery choose battery.
Now hit calibrate.
1- Recharge
2- Discharge
2- Recharge
Let the puter complete all of the sessions without interruptions.
That will calibrate your battery to charge correctly. thanks.
Nov 07, 2010 | HP Compaq Evo n610c Notebook
Sir its battery backup in 2hours but i am not satified to the backup i want this backup above 3hour
For this issue, you must calibrate the battery.
This will solve the problem.
There are 2 options to calibrate the battery.
Some bios version support this and have this options in it.
To go in bios press DEL button or f2 button.
Second option is run utility from windows.
This option will be best if you are not so accustomed to bios
Normally you have special utility software that came with the batch of drivers.
This are provided as part of support from the manufacturer.
It will take you 4 to 5 hours to complete the process.
While calibrating it will charge and discharge the battery several times.
Try this
OK
Feb 20, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
Bought new battery for ev0610, charged it for 24 hours but still no power?
restart your laptop press F10 to access the bios setup page. Now scroll to battery calibration tab follow these steps
1 Recharge
2- Discharge
3- Recharge
Your Done!
Feb 07, 2010 | HP Compaq Evo n610c Notebook
Compaq Evo N610C Notebook Logo
125 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
