Here are the code for soft reset *#7380# and hard reset *#7370# nokia mobile. Hard reset delete data on your nokia e5 but it will also remove your security code and reset to default. this will unlock your nokia mobile. and it your mobile is sim locked than t-mobile unlock and at&t mobile sim unlock is different. How to Network Unlock Att Mobile . in that case you need sim unlock code for your nokia. you can get free from online as per your imei number. even you can do bootloader unlock on your nokia mobile.
here is other way to unlock nokia mobile.
First power off nokia mobile then simalteneously press and hold power button, *,3and call button. Once nokia log on screen release all key button. This will factory reset nokia. Default nokia code is 12345. http://mobile-cellphones.blogspot.com/
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
What kind of lock it is? If it is a phone lock, You can do a master reset to your mobile. This could restore your phone with default factory settings. If it is a network lock, You can get the unlock code from www.mobileunlocksolutions.com/nokia-e5/rs1wp9/ and also you can get the unlocking instructions from www.mobileunlockguide.com/nokia-e5 for free.
If you forgot the security password, then you need to master reset the phone. Nokia E5 are BB5 phone which you cannot get free master reset codes. I recommend you to contact the service provider of the phone to get the master reset code.
--- SOFT RESET (basic reset) This option restores the .ini files from the ROM. Does not erase data (photos,videos, documents) or applications from a third party. Key Code *#7780# (clickthis combination of keys on the keyboard in the mobile)
--- HARD RESET (total reset/formatting) This option restores the original operating system from the ROM. Formats the C:partition and deletes all data including the memory card. Key Code *#7370#(click this combination of keys on the keyboard in the mobile). You can also achieve Total Reset by pressing and holding down following keys: * + 3 + Green Button (call) immediately after turning the mobile on.
Important: The battery must be full and the mobile device connected to thecharger. If during the course of reset, the mobile stop receiving electricityit can ruin the internal flash memory of the mobile device and stop function
You can Unlock the Mobile from the Security Lock or Password Lock using the Master Reset Code,You can get the Master Reset Code at
http://www.superunlockcodes.com/unlocking-services/rs12wp6/ and Unlock it.I unlocked My Nokia and Alcatel Mobile from the Security Lock using the Master Reset Code...
