Question about NEC Express5800 120Le Server
System is running 100%
1) Task Manager under the Performance Tab - that the machine is running at 100%. Of course the direct result is a slow answering, slow running VM system. Any ideas? Its still running NT 4.0 2) Is it difficult to move it to a new server? What is needed to upgrade the entire system? Thanks Rusty Fenn,CIO US Merchant Systems, LLC rusty@usms.com
    Novelist:
    Champion:
  • 277 Answers
Before buying, try to find the specific process which use most of the system resources. make sure its not a spyware (use lavasoft foe example) or something you can eliminate from the system start up (msconfig...). Anyway, all you have to upgrade is the SDRAM memory. buy another 512K and it will run like the wind :) Good luck.
Posted on Nov 30, 2005
SOURCE:
Why does my dell m6400 overheat? slow performance
Press ctrl+alt+del to see task manager. Go the performance tab. If the cpu usage percentage is high. You system has been affected from virus.
Aug 14, 2014 | Dell Precision M6400 Notebook
Tip
Computer CPU/Processor maxed 100%
Is your computer experiencing a CPU that is running at 100% Is your computer experiencing slow performance?
You can view your CPU utilization and other performance stats using Windows Task Manager. Press Ctrl + Alt + Delete and bring up Task Manager. Go to the performance tab.
The top of this screen should show your CPU stats.
In Linux you can use the TOP command,
Type the top command:
$ top
A CPU that is running at 100% utilization is not necessarily a problem. When the computer is booting up, or coming out of sleep mode, it may max out the CPU which is normal. The CPU will be utilized fully in order to bring the computer up as fast as possible. Some computers will even utilize the CPU while it is idle, to complete background task such as disk cleanup and file reallocation.
A problem will occur if the CPU stays maxed out. If it stays at 100% for more than a couple of minutes, you may be experiencing degraded computer performance.
Steps to reduce performance degradation.
-In a limited number of cases, software bugs can cause CPU utilization to spike. You will know this is the case if you are using a computer program(that is not hardware intensive like photo/video editors) and notice degraded computer performance. Check your CPU stats while running the program. If this is the case, check online for solutions and possible upgrades which resolve bugs in the software.
-You can reduce Windows start up programs, which will speed up the boot/wakeup process. You can do this from the MSCONFIG window. Go to Start > and in the run box type "msconfig". Go to the "startup" tab and you can uncheck which programs you do not want to start with Windows.
-A majority of the time a computer will get to a point were the hardware will need to be upgraded in order to handle the work you are doing. Common computer upgrades are memory, cpu, motherboard and hard drive.
-G33k
on May 15, 2011 | Computers & Internet
My laptop is operating very slowly!I dont understand the problem!
1. First of all download and install CCleaner, it is free.
Here is the link http://www.filehippo.com/download_ccleaner/download/1d59b13e3d0824a0c054077615cab5c3/
2. Run the exe and then follow the instruction to install the ccleaner.
3. After opening the ccleaner, select all the check boxes inside the cleaner tab.
4. Click on Run Cleaner.
5. Click on Registry in the left side tab.
6. Click on scan for issues, then click on fix selected issues. Click on no when asked to back up.
7. Go to Tools Tab and then click on startup tab, Now uncheck all unnecessary and unknown application from being startup.
8. Restart ur computer.
Check now the performance.
If you think there is any virus in your pc, then scan your pc with ESET NOD32 On demand scanner or install Quick Heal. If you want free antivirus then download and install avast home edition 5.0 and register for 1 year free license. (WWW.AVAST.COM)
** After doing all this, if u further want to improve ur system performance then tell me the Operating System installed in your system then I will tell you how to improve.
Jan 31, 2011 | Computers & Internet
Slow Computer
Could be lots of reasons. First thing you're gonna want to do is backup your important files.
I'd say it's time for a format / re-install.
You could try figuring out the exact problem(s) but it's much smarter to do what I suggested.
Trust me.
Nov 20, 2009 | Compaq Evo N1020V PC Notebook
Processor running at max!!!!!!!!!
having too many desktop items can cause a computer to slow down
Oct 15, 2009 | HP Compaq 6735s Notebook
Computer suddenly slow!
There could be a number of things that is slowing your computer down and it depends upon what is running on the computer and in the background.
For example. Someone could have hack into your computer, assuming you are on an unsecured wireless conection. A virus program is using or accessing data on your computer. Your virus program is running a scan on the computer. If you are on the Internet and the service is slow because of the amount of traffic through your ISP's connection.
The way to monitor what is going on is to run Windows Task Manager.
Press Ctrl-Alt-Del keys together to open Windows Task Manager.
There are 5 Tabs that view various functions. The Processes and the Performance tab give you details of what is going on.
In the Performance tab if the CPU is running nearly 100% that is why your computer appears slow.
In the Application tab, this shows which programs are opened and running, the more applications that are opened can make the computer slower.
In the Processes tab this shows exactly which process is running and who or what is using that process and the CPU usage. Click on the CPU label twice and it will sort the CPU usage from the highest to the lowest. You maybe able to determine the process which is causing the problem and work out if you can shut down this process/program or it is a problem that needs to be resolved.
I suggest that if you are using a wireless connection that it should be secured to prevent unauthorized access. Install a firewall and anti-virus program. Scan the computer for viruses and trojan horse programs etc.
Aug 19, 2009 | Dell Computers & Internet
System running very slow, programs not responding including anti virus which is not performing virus scan.
- Open Task Manager (Ctrl-Shift-Esc).
- Open Processes Tab.
- Make the column "CPU Time" shown (somewhere in menu).
You will see, which process eat the performance.
If Task Manager doesn't start, it must be a quite clever virus. Try
Anti-Malware
http://www.malwarebytes.org
It is free.
May 02, 2009 | Microsoft Windows Vista Ultimate Edition
Hp pavilion ze4560us processor slow
Probably what you should do first is download Malware Bytes and do a quick scan/clean of your system to make sure there is no malicious code on it.
Beyond that (if the machine tests clean) post your results and/or a list of the processes that are running so that we can further assist. Also, if you are currently running any anitivirus programs please post what kind.
Apr 03, 2009 | HP Pavilion ze4560us Notebook
Hard drive
When you say it's slow what I often found is that
1.not enough memory on your laptop
** so your CPU have to use your harddisk as memory,instead of working directly your CPU have another work to manage thus cos your system to slow down.
** you can check memory usage by right-click on your taskbar and click on Task Manager.Go up to Performance and check
Physical memory and see your available memory.
2.use more than one anti-virus program.Its just like before your work has been check by one program and now somebody is calling your same work to be recheck.Thus cos your system to become really slow.
3.Something is running all the time.A virus or something is running all the time.Shut it down by right-click on your taskbar and click on Task Manager.Go up to Performance and see CPU
usage that its 100%!!!! If so go up to process tab and right click
on the process you think is creating problem and End Process Tree.
3.The combination of not enough muemory and also not enough
harddrive space.When I say not enough harddriver I mean really low about 100-300 Megs.
so in your case not the problem with Harddrive..cos you have 1.5G
takecare.
Apr 27, 2008 | Computers & Internet
Computer slows up
Sounds like something is slowly using up all the memory on the PC. I would use the Task Manager to see what program is doing this. To start the Task Manager, go to Start -> Run and type: taskmgr The Task Manager window will then open. Click on the Processes tab. This will list all the programs and how much memory they are utilizing. Click on the Mem Usage column, and this will sort all the programs by memory useage. If you find one using an unusually large amount of memory, select it and press the End Process button. You will then be asked to confirm you want to stop it. Hit Yes. With this process stopped, see if system performance improves. You can also click on the Performance tab and see what the computer's resource utilization is, such as CPU and Memory utilization.
Sep 18, 2006 | Dell Dimension 4600 PC Desktop
NEC Express5800 120Le Server Logo
172 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
