Question about Maytag Washing Machines
Maytag washer. Model PAV1000AWW: It won't spin. Agitates OK. Water pumps out OK. Just won't spin. Makes no unusual noise. Bad transmission?
  • hackberrylab Sep 06, 2008
    Looks like the transmission died from water entering the case. When we removed the center post {under the agitator} we found an o-ring that had been sheared. Transmission is starting to leak a little water out onto the big plastic pulley. We'll probably replace the washer.
    Many thanks for the help!
    Scholar:
  • 141 Answers
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Posted on Sep 06, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
My Maytag washer agitates, and will pump during the spin cycle but will not spin
Check the lid switch is operating. It will not spin for safety reasons if it thinks the door is open.
If the switch is good test for power at the wigwag (spin) solenoid when in spin cycle. Since it agitates the solenoid itself could be bad.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
I have Maytag Model#PAV1000AWW which is a Top Loader.At this time the washer makes sounds in the spin cycle,but does not spin or drain the water.HELP!!!!!
  • it sounds like it could be a bad belt. tilt the machine over and look at the very bottom, you will see the belts. they are spring loaded and can be changed without any tools.
  • or you may need a transmission pulley and bearing repair kit ($30). this will fix the center pulley (spinning problem, not he draining issue) if it is stripped out. as you will see, the center pulley is made of plastic and does have frequent problems. but the good thing is that the parts are cheap and easy to change.
Jul 01, 2008 | Maytag Washing Machines
Washing Machines Logo
284 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
