Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Charging system why will my battery not charge?
Had same problem change voltage regulator.
Posted on Sep 16, 2008
1996 Aurora with intermittent charging issues. New alternator and battery.
Are you aware that this charging system is computer controlled ? There is also a temp sensor for the battery > Battery Thermistor
In addition to the voltage regulator the charging system also utilizes a battery thermistor, which measures battery temperature, in order to control system voltage. A procedure for replacement of the battery thermistor can be found in this section.
Oct 20, 2016 | Cars & Trucks
My can wont charge my battery and it wont rev about 2500 rpm in any gear. i have replaced cam sensor and crack sensor and put new timing belt and tensioner on?
My car won't charge my battery ? Check the alternator (charging system) . You put new cam & crank sensor an timing belt on for a charging system problem ? Or after you did this stuff ,now the charging system isn't charging the battery ?
Nov 10, 2015 | Cars & Trucks
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Why does system battery not charge ? new battery and new charging kit show no improvement on laptop. well charged battery works but not recharging.what is wrong ?
well this is a hardware problem.in this case your charging stage is not work.i am showing you a picture in the yellow marking fat 's are shorted if you can change these components the issue will be solved.sorry for bad english.
Jun 18, 2014 | Dell Inspiron Mini 10 N450
My battery light went on, on. My 2003 GMC ENVOY, the message board said "battery not charging" .....I took it to autozone and they said I had a bad alternator which is why it would say battery not...
The charging system on your vehicle is Computer controlled . called ( smart charging system )
BATTERY NOT CHARGING
The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
• The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
• The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1327
DTC B1328
DTC P0562
DTC P0563
DTC P0621
DTC P0622
DTC P1633
DTC P1634
DTC P1637
DTC P1638
These codes are all associated to charging system problems .
Battery light lit on the instrument cluster ?
Are You Smarter Than Smart Charging System MOTOR
Oct 27, 2017 | Cars & Trucks
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Batteries won't fully charge
mcdevito75 here, Sounds like the chargeing system has gone bad. Contact Pride online or phone.
Jun 27, 2010 | Pride Line Rally Scooter 3 Wheel Viper
How can I know that the Battery Maintenance System is charging.Does the battery voltage displays on the screen??
Hai dud,
A battery maintenance system for charging, analyzing, discharging and conditioning of a NiCad battery. The system displays voltage and capacity to determine whether or not a NiCad battery has enough capacity to power equipment for an optimal time period. The system charges the battery using a negative delta voltage method of detecting full charge, while also displaying instantaneous battery voltage. The system also analyzes the battery in a charge, discharge and recharge mode of operation, and during the charge mode the instantaneous voltage is displayed. The discharge mode discharges the battery to one volt per cell while displaying voltage and accumulative capacity alternately. The system also conditions batteries by cycling a battery through three cycles of charging, discharging and a subsequent recharge cycle.
Hope it Helped You!
Aug 03, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Jul 29, 2009 | Adapters.com Computers & Internet
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Lands Phones Logo
121 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
