Question about JVC HR-VP670 VHS VCR
Doesn't repond to buttons and stuck on rewind
I removed stuck tape in VCR and when I plugged it back in its stuck on rewind. Does not respond to any buttons I push.
    Novelist:
    Champion:
  • 277 Answers
... The takeup reel is turning properly but one of the reel rotation sensors or its electronics is defective. As a test, check to see if the tape counter is changing at any time during the loading and abort process. Non-real time tape counters usually get their pulses from this same sensor. Real time counters operate off of the A/C head control pulses and therefore would not be affected by a defective reel sensor). Some older VCRs used a belt driven counter - the belt may have broken or fallen off. Most newer VCRs use an optical sensor which may simply be dirty. See the section on: "Reel rotation sensors". 2. The roller guides are getting hung up and not fully loading the tape either as a result of an obstruction or dried up grease, or a slipping tape loading belt (often accompanied by an spine tingling squeal). Parts may have broken or fallen off of the roller guide assemblies preventing them from fully engaging the 'V-stoppers'. A similar fault may prevent the capstan from fully engaging against the tape d pinch roller. 3. The mode switch sensor is dirty or defective and confusing the poor microcomputer as to the position of the loading mechanism. In this case, the loading process may stop half way, pause, and then unload as in (1) or (2), above. Or, it may do almost anything. See the section on: "Erratic behavior in various modes". 4. Some other condition such as the end-of-tape sensor thinking that you are at the end of the tape is aborting the tape loading process. This might be indicated by a sudden reversal and shutdown rather than a pause (usually accompanied by the sound of a motor whirring) at some point attempting to complete part of the cycle. For problems with record in particular, the record protect tab switch may be dirty or worn resulting in random aborts. 5. Electronic problems like bad grounds or other bad connections are alos possible. Since with some models, (a number of JVC manufactured VCRs, for example) ground integrity is via screws through the mainboard, should these loosen, erratic behavior may result. Tighten the screws. 6. A defective microcontroller or other logic could also be at fault but this is less likely than any of the preceding.
Posted on Nov 29, 2005
    Novelist:
    Champion:
  • 277 Answers
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel
Tape stuck in vcr. when you press the eject button vcr starts to work but shtuts off the power Model number DVR-3034N. I have only taken the front and back covers off. Turned slanted roller untill the...
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
Jan 25, 2011 | Emerson Televison & Video
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Mar 08, 2010 | Sony Televison & Video
I have a VCR tape stuck in an old machine is there a trick to getting it out? It doesn't release it from the internal mechanisms! want the movie back!
I've had this happen to me a few times. The only way I could get the tape out was to take the VCR apart and carefully pull the tape out of the mechanism and all the tape that had pulled out of the cassette into the machine had to be carefully rewound back into the cassette. The tape itself is usually folded into many folds - so the movie needs to be copied as soon as possible onto a new cassette; as it won't play too many times with all the folds before getting stuck again into the VCR.
There is a little button near the door on the side of cassette itself that will allow you to open the door and rewind the tape easier.
Sep 21, 2009 | Televison & Video
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Problem ejecting tapes getting stuck
The take up is not rewinding the tape all the way back into the shell. Check the idler, it's either worn or if it's plastic it is warped from the heat.
Feb 09, 2009 | JVC HR-S6600 S-VHS VCR
Tape is stuck in the vcr and when you turn on the power it turns the tape about 10 seconds and then shuts off the power.
if the tape has snagged inside, the only way to get it out is to take the top of the vcr off and manually remove it. very simple procedure. only use your fingers and not anything sharp. have you tried rewinding the tape (from STOP mode) sometimes tapes can end up being wound very tight which would have the same effect. if you can rewind do so, then fast forward until tape stops, repeat this a few times this should loosen the tape.
Sep 21, 2008 | Televison & Video
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
VCR tape stuck
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Dec 18, 2006 | Zenith VCS442 VHS VCR
JVC HR-VP670 VHS VCR Logo
451 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
