Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
It doesnt turn on
When my hard drive is in the computer my computer wont turn on at all it only turns on with out it but i have no memory in the computer so i cant use it
    Scholar:
  • 55 Answers
Segate drives are prone to blow the diode between 12V and ground. When this shorts they draw masses of power (I have one which was smoking & drawing about 250W) and then the PSU won't start because of the short.
Put a meter over the small square diode marked something like BUX C??? (? are three numbers but they differ between drives) it should be about 10KO if it's more like 1 ohm then you have a short.
Clip it out & the drive will run, but it's a "penny in the fusebox" method - use it to recover your data only.
Clip it out & replace it with something like an SMD 1N4004 & you'll be back in business.
Posted on Sep 08, 2008
My pc doesnt load every time I want to turn after i boot the power and press 1st, 2nd, 3rd and 4th boot... in the screen I can see Dell is loading but doesnt move, i try to press F12 for boot and the...
Are you Sure that the computer model is Dell Optiplex GX260? Because looking at the manual diagnostic lights are found at the back. and the fault can be determine If the ABCD lights are yellow or green. But None the less 2/3 Depicts a hard drive problem while 3/4 depicts a memory issue.
Hard drive Issue:
1. Disconnect all non essential cables at the back of the computer. Leave only the mouse, monitor and keyboard. See if it boots up normally
2. If it boot up fine. try plugging one peripheral at a time until you find which peripheral causes the computer not to POST (Power on Self Test)
3. If you still getting problems, Follow these steps
4. To access the BIOS you must tap F2 or delete key upon turning the computer on
5. Try to look for the Hard drive if it is detected by BIOS if not got to step 9
6. Look for Boot Sequence or anything that is associated Boot
7. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
8. Save the changes and Restart
9. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
10. If Step 9 did not work I think you need to replace the Hard drive
Memory Issue:
1. Open the chassis of the computer
2. Try taking out all memory modules
3. Rub the metal contacts of all memory with a pencil eraser
4. If more than one memory. Put one memory first and turn the computer on. If it turned on add another memory and turn the computer on. Repeat these steps until you determine which memory is faulty or all memory module contacts needs cleaning
Jun 16, 2011 | Dell OptiPlex GX260 PC Desktop
How to turn on my dell computer it wont come on cause the hard drive is full how do i clean it to make my computer come on
a full drive wont stop it booting up take off the cover and remove the battery inside wait 10 mins and retry if it doesnt work you may have power supply problems
May 30, 2011 | Drive DSR-2000e
Every time i turn my system on it says the Ps3 will restore your corrupted hard drive, i finish restoring it then it restarts and i keep having to restoring it again and again. Is there anyway I can...
How are you restoring it? You need a memory stick and you need to find the update on playstations website and follow instructions on how to save it to the memory stick. Then you insert it in the ps3 and it should start restoreing from the memory stick. Atleast this is how you do it when your putting a new hard drive in your ps3 or a used laptop hard drive. It wont restore if it doesnt know what programs to put on it.
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
Im a owner of a simpledrive model no. 96300-41001-065 1tb external hard drive for my mac. when i first got it it worked fine. today it decided not to work for me... when i turn on my computer, it doesn't...
drive may have gone bad. the enclosure or enclosure electronics may be at fault and drive may be good
do you have a different computer to test it in?
Are you sure the power supply is providing proper voltage?
Apr 23, 2017 | Computers & Internet
My hard drive wont connect, and the computer doesnt recognize it.
hi have you used hard drive password to protect then remove the password if not then if your HDD is making lot sound and not able detect that might be your HDD is gone (HDD=hard disk).
Jun 25, 2010 | Buffalo Technology 250GB USB SATA 2.0 HD...
Makes a beeping sound when on
this is a memory module issue. take the the memory module and use pencil eraser and clean the metal strips of your memory module then put it back in to your computer then observe. if same issue will happen, then you have to buy new memory module.
Mar 27, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
My computer screen is stuck on hp logo nothing including key is responding my computer is stuck on hp invent screen.... it wont go past that, doesnt respond to f8 or esc. HELP
Sounds like a faulty hard drive that is locking up the system. Take out the hard drive completely and turn on the computer and see if it goes past the HP screen. If it does then the hard drive is bad. If it still locks up on you then reseat the memory one stick at a time in one slot at a time. If this doesnt work then you might be having motherboard issues.
Try these things and let me know what happens and I'll help you further.
Ben
May 18, 2009 | HP Pavilion dv2000t Notebook
Reseat the hard drive
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Feb 03, 2009 | Dell Inspiron 1525 Notebook
My computer wont turn on it just keeps making a beeping noise it doesnt stop till i turn of the power
Usually it is a loose component or a bad component. Usually a memory card or a hard drive that isn't plugged in all the way.
Check your connections.
Jun 10, 2008 | Intel Pentium 4 505J Prescott 533MHz...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
127 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
