Question about Sharp CD-BA150 Shelf System
HELP when i plug my sharp cd-ba150 protect stays on the display?
  • lilkev_16 Mar 01, 2009
    when i turn on my stereo the message "PROTECT" stays on the display. i cant do anything with the stereo.
  • 624 Answers
You have a blown amplifier IC in the stereo that must be replaced, that is what causes the protect error on the display. It is a good idea to take it to a repair center and have them do it if you are willing to spend about $125 to $150, depending on the rates of the shop, to have it repaired. Otherwise, you will just need to get a new one. There is no other way to fix this problem without replacing the amp IC.
Sorry for the bad news, I wish I could have given you an easy fix, but there just isn't one for this problem.
Let me know if I can be any more help.
Posted on Sep 06, 2008
I am getting an error Message 0306 or 0203 when trying to open the cd tray on my Sharp CD-BA150 Stereo System what can I do to fix this problem
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
Jan 18, 2011 | Sharp CD-BA150 Shelf System
My sharp cd BA150 is in Protect mode. What can I do?
The protect mode indicates that a problem was detected in the final stage of amplification and the unit has shutdown to prevent further damage. These units use an AMP-pac part number: VHISTK40270N1 which is available at for $53.09 plus shipping.
Nov 06, 2009 | Sharp Multi-System Mini Component System...
On the power display it say protected
I'd check the wires. Make sure NO unsheilded positive and negative wires are touching. Make sure that there isn't a speaker where the positive is on one channel and the negative is on the other
Oct 11, 2009 | Sharp CD-BA150 Shelf System
I tryed to have additonal speaker on my sharp cd-BA 150 player all sudden stop working and gave me an error message "PROTECT" so how do I fix that?
The output amp section for your system is not designed to run more than the speakers that come with it. By adding more, you presented too low an impedence load to the amp and overheated it. This occurred too quickly for the internal protection circuits to kick in to prevent damage to the outputs. This unit will now require that the outputs be replaced. These are not the easiest units to work on, so I would not suggest that you attempt this repair yourself. Expect a parts cost in the $35 range for this repair. Dan
Jun 09, 2009 | Sharp CD-BA150 Shelf System
I need help
It shows "protect" because the amp IC is blown. You would need to replace it or take it to a repair center and have them do it. The repair cost is normally from $125 to $150, depending on the rates of the shop. If you do not have really good soldering skills and know how to dis-assemble and re-assemble these type of units, you really should just take it in for service.
Let me know if you need any more help.
Sep 06, 2008 | Sharp CD-BA150 Shelf System
Protect screen on my sharp cd-ba150
that is your movement protection. In your manual it says how to get rid of it. mostelikely you have to push power and open button at same time
Jul 08, 2008 | Sharp CD-C662 Shelf System
My audio system says protect on display
As Shown Here, A Sharp-Associated Repair Person Suggested Replacing A Specific Output IC, As Well As Two Other Small Components. The Total Of The Three Replacement Parts Is $55.43. I Suggest Doing The Repair Yourself, As The Stereo Would Be No Longer In Warranty, Unless You Have No Experience With Working With Electronics. You Could Also Get The Repair Done By Circuit City, Best Buy, Or A Similar Electronc Consulting Business
Jan 10, 2008 | Sharp CD-BA150 Shelf System
Says Protect on the screen when i plug it in
Most likely cause could be a blown power amp IC. The part number is STK402-040.
Nov 06, 2007 | Sharp Multi-System Mini Component System...
Sharp cd ba150
Oct 25, 2007 | Sharp CD-BA150 Shelf System
CD Player
Does the cd draw open an close freely? Possible it could be the cd loading belt needs replacing. Its located at the top right side below the mechanism.
Oct 09, 2007 | Sharp CD-BA150 Shelf System
510 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
