Question about Samsung DVD-R155
I don't want my DVD's to Auto finalize when I open the drawer
Every time I open the drawer after I have recorded something. It finalizes the disc. That didn't happen with my Samsung R130. I wanted to know if there is anything I can do to fix it to a manual setting.
Thanks a bunch,
Laura
  • Steve Froese
    Steve Froese May 11, 2010
    What application are you burning disks from?
    New Friend:
  • 109 Answers
First your product manual that goes with your unit there it explain the procedure how and if you lost it goto dvd menu then check for recording settings.
Posted on Oct 18, 2008
How to finalize a dvd
Which specific model of DVD recorder do you have? You need to finalize the disc on the unit that wrote the files/movie to disc. For the Toshiba DR570KU, press Setup on the remote. Then enter the DVD menu (use the up/down arrows to navigate and then press Enter). Select Finalize and then press Enter. Highlight Yes when asked to confirm the finalization step and then press Enter again. Wait for the recorder to finish the process (it will take several minutes). Note: you need to leave some space on the disc for the finalization data to be added to it.
You can also set the unit to auto-finalize when the disc is full or a timed recording ends. For the second item, you will not be able to add content to the disc if a short program was recorded unless you use a rewritable DVD. (Then you would will need to unfinalize the disc. See the manual.) This is accessed from the General Settings menu from the Setup button. Go to Recordings and then select the Auto Finalize setting. Select when you want the disc to finalize and then turn ON the feature. Press Setup to exit the menu.
The manual for the DR570 is available under the User's Guide tab here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805105&rpn=undefined&modelFilter=DR570KU&selCategory=2797338&selFamily=2797342 . Toshiba has the manuals to most of their products here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp .
Please add a comment with the specifics of your recorder for more information. I hope this helps.
Jul 01, 2012 | Toshiba Televison & Video
Finalizing a DVD-R blank disc
try changeing the disk name and then see if the finalize option is availalbe.
Jun 18, 2008 | Sony RDR-GX315 DVD Recorder
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
Disc will not finalize dvd r disic will not let you go into the menu to finalize
If the disc is not full yet ,try to record something else onto the same disc (even a minute ) and try to re-finalize it.
If it does not work take the disc put it on the laptop DVD reader to see thru Hope will solve the problem..
Thanks in advance for rating me..
Regards
Oct 22, 2010 | Philips DVDR3380/05 DVD Recorder
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
Dvdr3576h will record on dvd+r but will not play on other devices
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
Nov 14, 2008 | Philips DVDR3576H DVD Recorder
No disc kicks disc out
I have the problem of it refusing the disc if the door opens before I have filled the whole disc and finalized it. As long as I don't open the door till the disc is full and finalized, it works.
Aug 30, 2008 | Samsung DVD-R130 DVD Recorder
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
How long does it take to finalize? Can I finalize on other recorders?
The finalizing time depends on the remaining time on the DVD-R disc; Approximately 8 minutes to finalize with 20 minutes recording time on disc Approximately 3 minutes to finalize with 10 minutes recording time on disc Approximately 2 minutes to finalize with no recording time on disc. DVD-R discs recorded on the DVD-Camcorder cannot be finalized on other DVD-R Recorders or PCs.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Samsung DVD-R155 Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
