Common problem. You are in for a rough ride my friend. The only way to fix that is to remove the rest of the bolts, the front crankshaft dampener pulley and take the timing chain cover off. Usually the bolt is seized into the timing cover itself and the timing cover ends up getting destroyed in the process. Once the cover is out of the way, the bolt will most likely come out fairly easilly with a pair of Vise-Grips.
Fortunately, a replacement timing chain cover is not real expensive. The trick is to get the [BLANKETY] thing off without causing any damage to the engine block. If you are going that far, I recommend putting a new timing chain set on it while you are in there.
Recommended parts: Timing cover gasket and front seal set, timing chain and gear set, and possibly a new timing cover unless you can get it off without ANY damage.
Keep in mind that if you have to pry it off and the pry tool leaves indentations in the gasket surface, or if you "warp" the cover, the timing cover MUST be replaced unless you want to do the job over to fix oil and engine coolant leaks. (It doesn't take much to make the thing leak)
