I own the technosonic sx-009 wireless headphone and can't for the life of me remember how to set them up.
My ipod bluetooth is on but I can not get my Sx-948c headphones to wireless connect.
YOU HAVE TO POWER ON YOU HEADPHONES , THEN SEARCH FOR IT IN YOUR IPOD THEN CONNECT ,
Oct 23, 2013 | Universal SUICEN SX-948C Bluetooth V2.1EDR...
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I have a Pioneer SX-315. When I try to change any of the settings I get a 'phonesin' error messagr on the display.
It's telling you it thinks the headphones are in. Remove them or troubleshoot why it thinks they're in.
Feb 27, 2011 | Pioneer SX-315
I can't find the pairing codes for my ns-bthdst
the code on the PC side should be 4 zero's, there is no code to set on the headphones side of things, just power the headphones on and on the PC set to serch for new devices.
Feb 17, 2011 | Insignia Bluetooth Wireless Headphones...
Technosonic lcd2017d stand lost
Hi I have a technosonic LCD3251 tv and am trying to take the stand off, as it is wall mounted now, i have taken all the screws out but i still cant get it off!! D you remember how you took yours off?
Jul 26, 2010 | Televison & Video
I need to replace my remote for the Technosonic SA 201 DVB freeview but I need the code to set up the new universal remote. Any thoughts. many thanks Duncan
You SHOULD get the codes with a new Universal Remote.
Have just gone through my lists but they do NOT show a Technosonic anywhere in them.
Feb 02, 2010 | Televison & Video
Voice service kills audio with insignia wireless headset in Second Life
perhaps it stills has an option to assume total priority over anything else for the particular program you are running, check its details and settings,,,,all else fails removeit....it cant, or shouldnt climb out of the trash can.....**crosses finger**....
Nov 03, 2008 | Insignia Bluetooth Wireless Headphones...
I don't know how to work my Wireless Bluetooth Headphones. Sony(Wireless Stereo Headset DR-BT22)
I went to www.sony.com, clicked on customer support, typed in the model number of my headphones, and then clicked on the "operation" link.
A PDF file came up and told me exactly step by step how to use my headphones.
Jul 26, 2008 | Sony Computers & Internet
66 people viewed this question
 Grubhead
Grubhead
