On The Dual Input Model I connected one to the monitor but there is no place to connect to the computer. On the instructions it shows it is connected on the bottom of the computer? Also, can not get my printer to print; It is a Acer model Aspire M3100. HELP Thanks, christine
    Sergeant:
    Champion:
  • 331 Answers
You will have to meet the suppliers
and ask them about the exact location of the input
Posted on Sep 06, 2008
Got struck by lightning via the modem which was destroyed. The port that accepts the ethernet cable stays on as soon as the computer is plugged in. Power comes on but no input to the monitor.
The modem might have been obviously destroyed but so is the rest of the computer. The connection that you are talking about is the NIC and it is showing signs that it was damaged by the surge also. That means all the delicate electronic parts in the computer are toast. Time for a new computer.
Aug 24, 2015 | Sony VAIO PCV-RS710GX PC Desktop
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
No signal input wen connected to the VGA port of my Dell M1210 (Win 7). using an VGA to DVI cable. If i connect the CG223 to an old laptop (vga) it works fine.
The Dell M1210 hos only a VGA output or s-video output, both being analog. If you are connecting the M1210 VGA to the DVI input on the monitor then this will not work. You need to connect to the VGA input on the monitor.
May 25, 2011 | Eizo CG223WBK Monitor
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
Flatron W2353V Monitor shows no video feed
My pc has 2 places to connect a monitor, due to the fact that it has an integrated generic quality video card (which didn't quite excite me enough), so I installed a higher quality graphics card. So, make sure that you have connected correctly.
Also, there should be an INPUT MODE selection somewhere on the monitor itself. Mine has a series of buttons on the lower right side, one of these is INPUT.
On a side note, you may need to download drivers for it; I have located the manual and drivers for this item here:
http://www.lge.com/us/computer-products/monitors/LG-lcd-monitor-W2353V-PF.jsp
Hope this helps.
Dec 15, 2009 | LG Flatron L1510S 15" LCD Monitor
Video Input Selection Problem
That is due to the fact that you can only connect 1 desktop to the HP LP2465 as most monitors.
For one the LP2465 does not have the picture in picture technology and for another the two ports you are connecting your Macs into are DVI (Digital Video Interface) connections. One is the Single DVI and the other is a Dual DVI.
It does not mean you can connect two Mac computers to the same display and both work. That is not practical because there is only one video input interaction possible with a computer and a monitor.
The DVI connections are determined by their ability to use either Analog and Digital signal transmissions through one connector.
So in order to effectively use your HP LP2465, you can only use 1 computer with the monitor because it is not designed to work with two computer graphics cards at once. Most LCDs have only one DVI or VGA connector to connect to a computer- your just happens to host two types of DVI connections is all..
That is the reason one computer is on with your display and the other is not displaying any video.
Take a look at this great explanation of the differences between Single DVI and Dual DVI connectors via this link:
Digital Video Interface (DVI)- Defined
Regards,
-Terry
Feb 13, 2008 | HP Lp2465 24 in. Television
Dual Monitor
To arrange multiple monitors
This procedure applies when two or more monitors are connected to one computer.
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Identify to display a large number on each of your monitors, showing which monitor corresponds with each icon.
  3. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
note.gif Notes
  • To open Display, click Start, click Control Panel, and then double-click Display.
  • The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Feb 13, 2008 | Computers & Internet
Switch to alternate 2 computers and dual monitors
What you probably want is a KVM (Keyboard, Video, Mouse) switch that supports dual monitors. It's a simple device that allows you to plug multiple computers into one set of monitors, keyboard, and mouse and switch between controlling them.
I don't know of any that support mixing analog and digital connections for the monitors, but using a VGA to DVI adapter for one of the monitors should solve that problem cheaply.
Dec 14, 2007 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
