Question about RCA F19436 19" TV
Set will not turn on
Set is dead. It will not power up with remote or manually.
    Novelist:
    Champion:
  • 277 Answers
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Posted on Nov 29, 2005
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
Philips 19PS50S122 TV does not respond to remote control
Please check your batteries in the tv remote as they appear to be weak or dead. You will need to find the cable remote's paper guide in order to properly program the cable remote so it can change channels, volume, and power functions on the tv set.
Good Luck!
Rich Lilja
Jan 05, 2014 | Televison & Video
My insignia tv will not turn on
If its total dead look for a fuse inside and if bad replace it. If any light comes on but set does not you would at the least need to open the set and inspect the power board for puffy filter caps and for voltages coming in and going out of that board.
Dec 20, 2012 | Insignia NS-LTDVD19-09 LCD TV
My tv wont turn on the blue light goes out but no picture
Have you tried turning on your TV using both the remote and the power button on the set?
If it's a problem with the remote, it could be dead batteries, a blocked sensor or the remote is no longer programmed correctly. Try replacing the batteries and see if that solves the problem.
If the remote is accidentally reset or sits with dead batteries for a while, you may need to reprogram the remote with the proper codes. Check your owner's manual for the codes and directions on reprogramming it. For more help with your remote, check out Remote not working for possible causes and solutions.
If the problem is with your TV and not the remote, there are a number of possible causes from loose cable connections to dust build up to a backlight lamp that has failed. For a simple troubleshooting checklist, see TV picture problems and learn about simple fixes for the most common problems. I hope this helps!
Sep 13, 2012 | Televison & Video
Our proscan 1080p wont turn on with the remote. Any ideas??
Dead batteries in the remote ? Is it a universal remote correct component selected ? Will the set turn on at the TV power button ? Hard to say with such a vague description. These should give you more information to interject.
Jan 02, 2010 | Proscan 42LA45H 42 in. LCD TV
Remote not turning tv on
if your tv set can be switch on manually then you need to replace the remote control.have you tried changing the batteries of your remote?maybe it is already dead,if you tried then buy a new remote control.
Nov 30, 2009 | RCA Televison & Video
1993 Sony Trinitron 27"
as set is dead the problem is in power supply or horizontal section. though it is a simple &less time taking. but if you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors and transistors in the power supply or the sweep power supply. Good Luck
Sep 30, 2007 | Televison & Video
RCA F19436 19" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
