Question about Rockford Fosgate Car Audio & Video
I have an OE unit(CY468) in my 2002 Nissan Sentra. The CD player has stopped playing CD's. It ejects the disc and gives an "Err" message. What can I do to fix this?
5 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: denon udcm m7 cd player often reads ERR on play and eject
Try cleaning the laser first. Take care, because it is delicate.
Some instructions of how to clean a CD laser:
http://www.wikihow.com/Clean-a-CD-Player
If the cleaning does not fix the fault, it is possible that the laser is weak, or there are some problems in the electronics in the CD player. This is not something you will be able to service yourself, unless you are properly trained, have experience, and have the proper setup to perform CD player servicing.
In most cases these CD players are not cost effective to service. You can contact the orignal manufacture for details or any recomendations.
Jerry G.
Posted on Apr 29, 2008
  • 3 Answers
SOURCE: 2001 nissan pathfinder cd player shows ERR.........doesn't work!
On my 2002 xterra 6 Disk player.
It locked up on me.
I was able to fix it with key in the off position. I pulled the Radio fuse and put in back in.
The fuses are located under the hood on the left side right behind the battery.
Then I turned on the key and the radio. The CD began working just fine.
Posted on May 09, 2009
  • 232 Answers
SOURCE: CD Player not workinig
Try using a cd player cleaner disk, then remove the radio fuse in the fuse block wait about five minutes then re-install. This is done to restart the radio. If that don't work disconnect the negative from the battery, wait five minutes then reattach, this will restart the cd player for sure. This will also restart the car computer just so you are aware.
Posted on May 13, 2009
localwonder
  • 6784 Answers
SOURCE: 2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
Posted on May 21, 2009
SOURCE: cd is stuck in my cd player and will not eject.
in supporting work how you would promote equal opportunities in the work place
Posted on Oct 07, 2009
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
04 Nissan Sentra I have been reading the problems with the cd players. Our cd player is doing something a little different. When you put in a cd you have to eject it over and over and put it back in,...
Try using a cleaner disc and follow the directions, and if that don't work try spraying some compressed air inside the slot, just sounds like has a dirty lens to me.
Nov 08, 2010 | Sony Xplod CD Player w/MP3 Playback...
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
Cd stack in cd player,screen shows err
My CD Player did the same. It showed an "ERR" message when trying to detect the beginning of a CD. I thought that the CD was dirty and wiped it down. Then I discovered that the player would detect the CD when the car was idle, but not when the car was in motion. Maybe the laser is THAT sensitive. Hope this works for you.
Jun 29, 2009 | 2002 Nissan Sentra
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
May 28, 2009 | 2005 Nissan Sentra
Cd player
There are cd cleaners that have tiny little brushes on them to knock the dust off the laser. It sounds like the lens is dirty and it isn't focusing.
Assuming, of course, that it isn't a non-MP3 player trying to read an MP3 format disk...
Nah, you wouldn't do that....
May 09, 2009 | 2003 Nissan Sentra
CD will not read or play....ejects ;;ERR message flashes Help
try different KnownGood cd and if still an issue your head unit needs repair internally .(not worth it)
Nov 24, 2008 | 2000 Chevrolet Silverado
Denon udcm m7 cd player often reads ERR on play and eject
Jerry G.
Apr 29, 2008 | Bose & Wave& Music System
Car Audio & Video Logo
62 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
