Question about Dell Vostro 1500 Notebook
Laptop won't startup
I get a flashing lock symbol on my keyboard apon turning my laptop on? The lock has a number 9 in it. The laptop won't boot up?
Please help
  • Anonymous May 12, 2009
    this is old, but in case someone stumbles onto this through google, this is usually a motherboard problem. i have seen this many times (especially in dells). if you press power and the num lock blinks a few times and stops and the pc doesnt boot, then the motherboard is usually bad.
  • Anonymous Mar 26, 2014
    what is this?
    New Friend:
HERE is the REAL answer to this question!!
First, Download this document:
Then go to page 52 (Diagnostic Light Codes During POST). It describes in detail all of the possible combinations of lights and their associated failures.
This solution holds true for other models of Vostro as well.
Some of the solutions I found for this are nuts!! It's obvious they will let ANYONE post on here, even if they have no clue what they are talking about!!
Posted on May 07, 2014
Just push "num lock" button :).  This flashing Lock symbol [9] means "Num Lock" is on - numeric keyboard enabled. If you wish turn it on or off just press the <Num lock> key, sometimes you have to use the <FN>+<Num Lock> keys.
Posted on Sep 27, 2008
  • 81 Answers
Try removing your battery and then putting it back. If that doesn't work, then either your hard drive is bad or maybe even your motherboard is bad. If you can get into your computer's BIOS, check and see if it will allow you to do a system restore from the BIOS page. As stated above, it is probably that your hard drive is bad.
Posted on Sep 06, 2008
2 Suggested Answers
  • 41 Answers
SOURCE: Vostro 1510
Possible memory issue. Try Reseating your memory card on the system, it would be helpful.
Posted on Oct 02, 2008
What do the lighted icons stand for at the top of the keyboard? One looks like a locked padlock with a 9 in it. What does it mean?
That is your number lock key is turned on, which means that your 9 key keypad is ready to use. If you press the number lock key on your keyboard the light will go away but your 9 key numeric keyboard won't work until you press the number lock key again.
Jul 29, 2011 | Computers & Internet
The function key is always on, on the keyboard. How do I change it back to a normal keyboard?
Press the NumLk/ScrLk button at the top right corner. That will turn off the 9-key number and symbol buttons. The Function key dosn't get stuck, just the number lock key.
Oct 18, 2010 | Panasonic Toughbook 19 Laptop Convertible...
There is a lock 9 symbol above my f4 button on my latitude e4300 laptop and i would like to know what this means?
The lock 9 is for num lock.
Usually there is a 'Fn' button on the keyboard of a laptop. It has to be somewhere near the 'ctrl' 'windows' or 'alt' button on the left.
If you press and hold the 'Fn' key and then the numlock 9, you will toggle numlock on and off.
The 'Fn' of the key is normally written in another color. There are several buttons on the keyboard thet has a same color number or sign. To enable this signs and numbers, you have to press and hold the 'Fn' key and then the key with the desired number or sign.
Sep 13, 2010 | Dell 0Y3740 Keyboard
Dell inspiron 2200 laptop - what are the 4 lights on top right of keyboard for? the first one is constantly blinking and the others are never lit up
Hi those are your keyboard and status lights
Looking at your laptop from the front the first light on your Right hand side is your scroll lock light and is only on when you press the scroll lock button (the symbol shows a lock with a little down arrow)
The light to the left hand side of that light is your caps lock light and again only turns on when you press the caps lock key (The symbol shows a lock with a A in it)
The light to the left hand side of that is your numeric keypad light (Symbol has a lock with a 9 in it), this comes on when you press the num lock key on your keybaord
Finally the last key is your hard drive light (like a cylinder), this will be flashing most of the time as you use your PC as it is constantly reading and writing data
Jun 10, 2010 | Dell Inspiron 2200 Notebook
On boot up a lock symbol with a '9' is lit & nothing else happens
the "9" inside a lock means that your Num Lock button has been pressed. If all you see is the ">" then maybe you are looking at what's called a DOS prompt, and I have no idea why that would display. Try holding the Power Switch for 10 seconds and restart your computer. Hopefully things will be better, and you know where your Num Lock key is.
Oct 10, 2009 | Dell Vostro 1500 Notebook
After being turned on the screen goes black and the lock key with the number 9 is illuminated ablove the keyboard
I had that happen to me with my Dell as well... If you're comfortable with taking a laptop apart.. you'll need to detach the screen ribbon, clean it with rubbing alcohol, and then reattach it. This should do the trick..
Jun 02, 2009 | Dell Latitude D400 Notebook
Key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
May 26, 2009 | Dell Inspiron XPS Gaming Mouse Pad KU170
Laptop Won't startup Vostro 1500
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Vostro 1500 Notebook
Vostro 1510
Sep 06, 2008 | Dell Vostro 1500 Notebook
Dell Vostro 1500 Notebook Logo
1,930 people viewed this question
Alun Cox
