Question about Panasonic DMR-ES40VS DVD Recorder/VCR
Two problems at the same time: VCR plays split screen and DVD player won't ready Disks (Errrrr)
Two problems started simultaneously, so I suspect a single cause. Problem 1: VCR plays a screen split in the middle and in black and white. Audio is fine. DVD player does not ready any disks at all and gives error message Errrr. Tried some of the standard things like reseting, and took off the cover and cleaned of the dust, but no luck. Changed Output cables and tried different outputs and even a second TV and no luck. Any suggestions other than getting a new one?
  • Anonymous Dec 12, 2008
    The VCR and DVD both play split screen and in black and white. It is also a shaky bad black and white picture.
  • 286 Answers
Getting a new one is about all you can do in this case. A repair for this type of problem would likely cost more than the replacement.
Posted on Nov 04, 2008
Why won't the DVD-RW disks FORMAT? I've seen others with the same problem with formatting multiple types of disks... Please help.
If you are using a Sylvania DV220SL8 DVD Player \ VCR combo (which this question is posted under the heading of) there is a very simple reason why you can't format DVD-RW disks. DVD Players can't do that. You need a DVD Recorder to format DVD's.
This applies to all comments under this heading as well. You can not record if the unit you're using does not have that capability. And this unit does not have it. You can record with the VHS VCR, but the DVD Player is just that... A Player. It's not a Recorder.
Sep 09, 2011 | Sylvania DV220SL8 DVD Player/VCR
Player won't play some of my DVD movies
have you tried playing them again from "cold start" that is not after 5 in a row ?? are the disks clean and free of dust etc ??
Mar 09, 2009 | Samsung DVD-V1000 DVD Player/VCR
Dvd disc won't play
Maybe the laser lens are dirty and need to be cleaned
Nov 04, 2008 | Samsung DVD-V5500 DVD Player/VCR
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Will Not Play CD-Rs Part Deux
Checked specs- YES -supposed to play MP3's. Did you try other MP3 Audio disks in the DVD? You can try the MP3 disk in your computer to make sure it is OK. If it plays in the computer, have to suspect a problem with the DVD unit - probably the converter IC.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Panasonic DMR-ES40VS DVD Recorder/VCR Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
