Question about GE 29267GE3 Corded Phone
Wall Mounting Exactly HOW do you reverse the handset hook (located on the base) to support the receiver in the wall mounted position?
  • pamsc Nov 02, 2008
    what is the hand set hook?
    Problem Solver:
  • 17 Answers
Slide it all the way up and out, turn it upside down and slide it back in.
Posted on Sep 17, 2008
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
I don't know how to take my Gatco 4515 "Tiara" Robe Hooks off the door now that I'm moving. Please help. Thank you.
I'm not 100% sure about this model, but I have a similar hook by another brand. Here's how mine is removed:
When you look at the hook, there's a small hole at the 6 o'clock position, (pointing down, right next to the wall.) This hole is actually a set screw that can be turned with a small hex-key (aka allen wrench)
thomascha103_7.jpg The size needed is pobably about 2 mm, or 1/16 in.
Turn the set screw counter-clockwise for a few turns to loosen the hook from the mounting bracket. When the set screw is backed out far enough, the hook will detach.
After he hook is removed, you'll be able to see the mounting bracket that is screwed into the wall. Remove the screws with a screwdriver, and take the mounting bracket with you. You'll need it to attach the hook to the new wall.
If there is no set screw or hole visible from any side, then your Gatco hook might be removed from the mounting bracket by twisting the entire hook counter-clockwise.
If anyone else out there has experience with this particular brand, please chime in and correct me if I'm wrong.
I hope I've been helpful. Good luck.
Jan 19, 2011 | Gatco 4515 Tiara Robe Hook Bathroom...
We purchased this phone and on the box it claims that it can be mounted on the wall. It CAN NOT be mounted on the wall as the receiver falls off it's hook. There were not installation instructions about...
Often there is a handset catch near the top of the cradle that must be reversed to allow the handset to hang in the cradle when installed as a wallphone. Typically the phone is initially setup as a desk phone, if this catch piece was reversed it would interfere with lifting the handset. Some models have a screw holding this piece in place, some just slide into cradle.
Dec 10, 2010 | Emerson EM-2646 Corded Phone
I installed a Moen Sage toilet paper holder. The right cover that attaches to the wall hardware via a small screw is loose and no amount of tightening corrects the problem. What am I doing wrong?
It is likely that the the mounting post on the wall has pulled loose.
You will need to remove the paper holder and inspect themounting posts; loosen the set screws in the base of the posts to do this.
Try tightening the screws holding the mounting posts to the wall. If the screws are unable to hold tight you will need to replace the wall anchors if they have been used.
Remove the mounting posts and the wall anchors and replace with new wall anchor, preferably a toggle anchor designed for sheetrock if possible.
With the wall anchors in place attach the mounting posts and install the paper holder; tightening the set screws in at the base of the posts.
Installation instructions for your product can be found here:
http://www.moen.ca/shared/pdf/yb2208sp.pdf
Oct 18, 2010 | Moen Home
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
GE 29267GE3 Corded Phone Logo
106 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
