Question about D-Link DIR-600 Router
My computers have stoped receiving IP address from D-Link DIR-600 router when using wireless. When connected using wire they receive IP addresses but when connecting using wireless the computers are shown under Staus -> Wireless but with IP Address filed as N/A. The computers are shwoing wireless connection as connected but have a private ip address in the 169 range. Would really appreciate any suggestion to fix the problem.
    Problem Solver:
  • 8 Answers
Try to manually input the ip is not automatic, the ip gateway router,continue to try again
Posted on Aug 21, 2011
SOURCE:
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
I can't setup my D-link DIR-600 router to allow remote desktop access to a Win-based PC on my LAN.
Try to assign a static IP address to each of your computers on the network. Its better to start at 192.168.1.151, 152 and 153 so on. These numbers are beyond normal dynamic IP Addresses! Then identify each computer with their IP Address then log on remote with their IP addresses! as administrator!
good luck!
Sep 12, 2011 | D-Link DIR-600 Router
Recently, i have received dir 615 route, it works on pc however, when i try to connect to my laptop it says limited access. p.s. i am using vista
Hi check if the same wireless name defined in your laptop if you have it go wireless setting remove the current name and try to connect , check the wireless encryption WEP or WPA you should have same setting for both Laptop and your router ,another thing u should check is make sure DHCP enabled on your router and on your laptop you should get IP address and DNS automatically also check the if you get any IP address it should be 192.168.0.* for your Router you can go to start type CMD then type ipconfig you will get the IP ADDress if you need more help please contact me on http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-625 (790069292637) Wireless...
Iam having different ips from wan is this mean someone is accessing my network?
You just have Dynamic ip, nothing to worry about.
"Static IP addressing is for one customer on one IP address and Dynamic IP addressing assigns a different IP address each time the ISP customer logs on to their computer, but this is dependent upon the Internet Service Provider (ISP) because some ISP's only change the IP address as they deem it necessary.
If you have Dynamic IP Addressing through your Website Host it means that you are sharing an IP Address with several other customers.
If you are a beginner on the internet, an avid internet user, are entertaining the thought of starting your own website business, are a gamer, use VOIP or VPN there are several things you should know about IP Addressing."
Read more
Mar 21, 2011 | D-Link DIR-600 Router
How to block my wireless router dir 600
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 27, 2010 | D-Link DIR-600 Router
I am able to use this router in wireless mode but cannot get it to work when hard wired to the router. What setting do I need to check?
When you connect the computer to the router with the cable, make sure that it is connected properly and there is no loose connection. Also if you are connecting the computer to the port number 2 on the router then make sure the port light will lit up.
Proper light should lit up.
Check if there is no static IP address on the computer. If there is a static Ip address then set to obtain IP address automatically.
Click here for step by step instructions
Mar 09, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do I change my security settings in my dir 600
If not then you will need to connect the computer to the router with the cable. Do not change wireless settings using a wireless computer.
Click Here for step by step instructions
Mar 01, 2010 | D-Link DIR-600 Router
Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Jun 06, 2009 | D-Link DIR-625 (790069292637) Wireless...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
D-Link DIR-600 Router Logo
105 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
