Question about Fossil CH2331 Wrist Watch
Condensation under glass (inside the watch) so can't read time?
  • Anonymous Sep 19, 2008
    Some problem here, called fossil they said its the back screws under the watch face. (Mine is an automatic but one would tighten these screws or loosen to remove battery) They claim it needs to be tightened, anyway send it in to them they replaced the whole thing and I still am having the same issue.
Tip
Condensation/water in watch?
A watch with condensation under the glass needs to go to a watchmaker without delay, even if the condensation disappears again after a short time. This is one of the worst things that can happen to a watch. It means that minute quantities of water have penetrated the case but the seals are still tight enough to prevent it from evaporating. What you have on your wrist is in effect a miniature hothouse, where the water condenses at the coolest point. The constant damp atmosphere inside the case is very corrosive and, at worst, can destroy the movement. Without watchmakers knowledge there is no way anyone can dry the watch out and not to damage it, so, rush to your nearest watch repair shop as quick as possible.
on Feb 16, 2010 | Watches
How to clear condensation
when you changed the battery did you replace the rubber seal on the back plate if not that's why you have condensation in your watch,dry off with hair dryer and replace seal ,then it will be ok...
Nov 19, 2012 | Garmin FR60 Wrist Watch for Men
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
Jun 01, 2011 | Swatch Watches
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Nov 14, 2010 | Bulova Chronograph Marine Star #96B99...
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
I have condensation on the inside of the glass on my watch. I have a pr50 automatic so i don't know if the normal jeweler will be able to fix it. It doesn't have a battery and was recomneded to me to send...
  • Decide whether the risk of possibly damaging the watch is worth attempting a do-it-yourself fix. If the watch is expensive, you may want to have a professional repair it rather than risk damaging the watch or invalidating the manufacturer's warranty.
  • Step 2 Lay the watch in a dry place in sunlight and see if the water evaporates on its own. Put a piece of soft, absorbent cloth such as a towel under the watch. If the water inside the watch face is only a fine film of condensation that clears on its own after a short time, you probably do not need to do anything else.
  • Step 3 Seal the watch in a plastic bag filled with unopened packets of silica gel desiccant. These are the packets that come in shoe boxes and other packaged items. You can also use dry rice instead of the silica gel packets. Leave the bag somewhere warm and dry for a few days. The silica gel packets or rice can help draw out the water from inside the watch.
  • Step 4 Direct a fan at the watch or use a hair dryer on the lowest heat setting to blow air on the watch. Alternatively, if you can safely leave the watch on top of a low heat source such as a floor vent or radiator, this can help evaporate the water from inside the watch.
  • Step 5 Obtain the appropriate watch repair supplies. If you need to purchase tools, look for these at a watch repair shop or at a jewelry store. You can also find watch repair tools online. You may need small, fine-tipped screwdrivers and watch openers and closers.
  • Step 6 Take off the back of the watch, as if you were changing the battery. Use care not to scratch or damage any of the mechanisms such as the coil or stem. Let the watch dry thoroughly in the open air until there is no trace of moisture. Reassemble the watch once it is dry and press the seal firmly back into place. If the seal does not fit tightly, you may need to replace it
  • Aug 14, 2010 | Watches
    Hi i wore my rolex in a hot tub & now it has condensation under the glass how can this be removed
    Before anything else, put the watch is a warm place and leave it there fore a day or so, it may dry out on its own.
    (Some manufacturers accept that small amounts of moisture inside are to be expected, so it may not be a disaster.)
    If it proves to be a persistent problem, then its back to the service center!
    Mar 01, 2010 | Watches
    Condensation
    On most watches, if you get condensation within the face, means that there is a small crack on the glass/plastic covering. Some watches you can take apart from the back and pull out the workings and replace this casing, on others, you have to take it to the jewelers to have it replaced. Depending on how much you paid for the watch, you are better off buying a whole new one.
    Sep 20, 2008 | Fossil BQ9184 Wrist Watch
    Fossil CH2331 Wrist Watch Logo
    127 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
