Question about Kenmore 98702 Stacked Washer/Dryer
Problem with wash cycle
Machine fills well, then in wash cycle makes a hum noise and do nothing
    Genius:
  • 1,028 Answers
Remove lower screws in front panel and pull panel down and off ckd motor connections also ckidler pulley and gearcase to see it either are stuck or binding
Posted on Sep 07, 2008
5 Suggested Answers
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
lojacksdad
  • 121 Answers
SOURCE: Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
Posted on May 02, 2009
SOURCE: Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
Posted on May 06, 2009
  • 132 Answers
SOURCE: My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Posted on Jul 15, 2009
Kenmore series 80 newer won't fill spin or agitate just hums on cycles and makes no noise on spin cycle
Are you sure the water is on and water is getting to the machine.
If there is no water the water valve will open & hum & nothing else will work till the tub is full.Check the little screens on the water valve behind the hot & cold hoses where they hook up the the machine they get clogged
up sometimes just pull them out and clean them. Hope this helps you
Jan 05, 2018 | Kenmore Washing Machines
Washing machine won't wash when on large cycle
without stating the make and model it makes it harder for us to help you figure them out .front loaders are more prone to this type problem than top loaders .could be the gear box is going bad or a belt getting stretched
Oct 06, 2015 | Washing Machines
Machine filled with water. .but doesn't start to wash. .makes humming noise
Either the motor is bad or the fill sensor is bad? Try switching it to the spin cycle if it doesn't spin more and likely the motor is bad ?
Feb 21, 2015 | Washing Machines
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
My wtw57esvw does not fill on any cycle. Any way
I don't know this model but the answer to your question is no unless it is a top loader.
Does the machine make a humming noise when it is on the fill cycle? If so then it is a problem with the fill hose knined or the filter where the hose is fixed to the machine. If it is a cold fill only and there is no noise on the fill cycle then the fill valve may need replacing. If it is a hot & cold fill, then it is unlikely that both valves have gone.
Oct 01, 2014 | Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
THANKS
Jul 15, 2009 | Washing Machines
Cycle starts, continual humming, no wash, no movement, just humming noises. Have to stop the wash.
If it hums from start, and it is filling fine from inlet valve, then the problem is usually timer control board or motor control unit board/motor failure.
If it gets stuck on filling forever, check also the pressure switch.
Parts must be tested before replacement.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Zanussi ZWF12070 Front Load Washer
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
91 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
