Question about Conair FRS310 (14 Channels) 2-Way Radio
Noise my radio makes a scratching sound that is annoying after you send your call. it is really loud in the field. is there any way to stop this noise?
  • 215 Answers
Does your radio have a knob or switch which is marked as "SQEULCH" If it's a knob just rotate it until the noise stops and then just add a little bit more. It sounds like the squelch is acting a bit slow after you let the transmit button go. If it's a switch I'm afraid it means a trip to a technician for adjustment. BMW
Posted on May 22, 2006
Making random loud bursts.
Connection wires? If your connection wires aren't that great or just won't plug in correctly or are not connected correctly the sound jumps in and out with random loud burst or sometimes a really annoying scratching sound.
make sure nothing is obstructing the plugs (going in), re wrap your wires(if you have the type of speaker with the loose wires you wrap yours) or upgrade your connection wires/plugs.
This may help? :)
Oct 29, 2013 | Klipsch Audio Players & Recorders
This ihome has been playing staticky noises.. It's really annoying PLEASE HELP ME.
Speaker is "blown up" because you have played the volume too loud, im not sure if its expensive or it has hq sound, but you should buy a different one, if you wanna play loud music you should get a bigger one. BTW NEVER play at max vol. or it WILL break if u use it too long.
Apr 14, 2013 | Audio Players & Recorders
My Keurig single brew has started making noise.
TAKE IT BACK! ! If it is only a month old and you still have the box and or reciept, it should be covered under warranty
Dec 28, 2009 | Keurig B60 Coffee Maker
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
Very loud "rubbing " sound when driving only
you did damage to the wheel bearing i bet it sounds like a airplane sound. also if you steering wheel is off 7"then have front end aligned because this will destroy the tires and they will make noise.
Mar 29, 2009 | 2006 Dodge Stratus
Washing machine makes a loud rattling sound
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Crackling Noise
I can't take credit for this because on found on a review on Amazon.Com, but I tried it and it works!
"Another update, for everyone who is having the common crackling problem, if you open the clock radio there is a black disk on the bottom with a red and black wire coming out of it. This black disk is a component called a piezo disk. They are commonly used to make noise for buzzers in electronic devices, but appear to have no use whatsoever in this clock radio. If you cut the wires going to this disk, the crackling noise goes away. You can still use both buzzer and radio alarms. There doesn't appear to be any functionality lost other than the annoying crackling sound. Obviously cutting wires would probably void your warranty, but do you really want to try your luck with another RCA clock radio? Chances are the crackling will happen again with the replacement or it will be DOA."
If you can handle a screwdriver and a pair of scissors, you can easily tackle this project, don't be worried about it being too complex. 5 screws, a snip, and you are all set. Make sure the radio is unplugged of course.
Sep 17, 2008 | RCA RP5430 Clock Radio
Buzzing loud noise constantly.
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Conair FRS310 (14 Channels) 2-Way Radio Logo
147 people viewed this question
Top Conair Radio Communications Experts
Mike Charette
Are you a Conair Radio Communication Expert? Answer questions, earn points and help others
