Question about RCA R52WM24 52" HDTV Projection Television
First a convergense problem and after a new board was installed it works for
15-20 minutes and then screen goes black and light in off and one switch flickers and power goes on and off but not long enough for a picture. Some background bowed colored lines are occasionally visible as set goes on and off? I have invested $320 with a recognized RCA repairman who is now stumped. Can you help?
  • MarilynM Sep 09, 2008
    I'm sorry but I have a perfect picture during the 15-20 minutes that the TV operates and I think that there must be an electrical overheat somewhere. I think the bad picture tube is poor advice since I have a good picture after the convergence board was installed. TV goes off and then off and on with black background and faint bowed rainbow accross top of the picture.
    Since I have two different opinions from two of your experts could I have a couple of other expert opinion before I consider spending a few thousand dollars on a new set after only 18 months with this one!
  • 423 Answers
Has your repairman checked the high voltage power supply?
Posted on Feb 11, 2009
    Brigadier General:
  • 5,158 Answers
Buy yourself a can of compressed air. when the tv quits start spraying quick blasts of air on components ... when it comes back on you have found the defect.
Robert
Posted on Sep 09, 2008
  • Roberta Smith
    Roberta Smith Sep 10, 2008
    the idea in that is you have an intermittent problem... the last time i ran into that it was a capacitor. i have no disparaging remarks for the repairman as intermittent failure is a pain to diagnose. if it is heat the blast of air will cool the component and the picture will come back on.
    Robert
    Master:
    Sergeant:
  • 462 Answers
Since you said that a part of the board was replaced.. u have a part of the solution in your hands like u said few places are getting over heated.. so its better to replace the filter components and resistors surrounding it... It may help...
Ismail
  • 4,234 Answers
FIrst of all, in order to provide you with the best advise, I'll need a little more background info. I assume that the original problem was a convergence problem and that the convergence ICs were replaced. Am I correct? If so, please post the IC part number (STKxxx). Along with those ICs, there should have been a check of a number of low valued resistors in the same circuit as well as any pico fuses in the area. If the resistors have either opened up completely or significantly changed value, the circuit will not function correctly and the protection circuits may kick in shutting down the set.
Update this and we'll go on to the next steps.
Dan
Posted on Sep 08, 2008
  • ABRsvcs Sep 09, 2008
    Since you have replaced the entire convergence board, the low valued resistors should also be new. I would be looking in the 24V power supply area for a bad filter capacitor. If the cap starts to fail, the 24V may drop mimicing poor convergence. Check also for poor solder connections in that area.
    Dan
    Have you checked the supplies as I suggested? Please update this.
    Thanks,
    Dan
    President:
  • 1,952 Answers
Thew problem is in picture tube...better u change ur picture tube and check...it may cost oly 500 to 1000..and also check ur televisio0n mother board whether the current passing thro it are proper or not
    Top Expert:
  • RCA Master
  • 78,289 Answers
This is a common issue, and it is almost always a high voltage circuit board problem, why? the greatest enemy of electronics is heat, so the parts that do the most work fail first. I have found that the repair cost so high that a new TV is the way to go, so you fix the first problem then a year later something else, just bite the bullet and buy a new LCD TV, they are cheap and very reliable.
  • yadayada
    yadayada Sep 10, 2008
    Fix it yourself
Samsung TV, UN60EH6003FXZA, Black screen, has audio. Replaced t-con board and TV worked fine for 5 minutes, then black wave came across screen. Can replace main board, is the new t-con board ruined?
If the new T'Con too have damaged, surely its main power supply regulator board is faulty. Over voltage to T'Con board. Replace it and the T'Con board. Never switch on the set, without proper fittings to T'Con board. Its protective cover should be fitted before you switch On the set. It acts as a shield as well as a heat-sink to the IC at the T'Con. If you switch On without properly fitted, the IC will overheat within minutes and will be damaged. Keep this in mind next time.
https://electronicshelponline.blogspot.com/
Oct 26, 2016 | Samsung Televison & Video
My telefunken flatscreen tv goes to a black screen just seconds after switching on. The screen shows for about 2 to 3 seconds and then turns black instantly. How can I fix this
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 14, 2016 | Televison & Video
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
Turn on laptop, loads fine, screen comes up, then screen goes black. computer is still running and you can see it if you put a flashlight on, but screen remains black.
Try to adjust the back-light on the screen by pressing the FN and UP arrow to increase the light.
If that does not work then it means that your back-light on the screen has either failed completely of works for a couple of minutes and then it goes off. You need to have your screen replaced with a new one.
Sorry for the bad news.
Sep 21, 2010 | Dell Latitude D600 Notebook
Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Jun 22, 2009 | Polaroid FLM-4201 42 in. LCD Television
I Think NO expert can help this problem because it free answer
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Mar 20, 2009 | Polaroid FLM-3225 32 in. LCD Television
Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to ptscorp.com, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Dec 15, 2006 | Fujitsu Plasmavision PDS-4209 42 in....
RCA R52WM24 52" HDTV Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
