We have a Intertherm Nordyne heater/airconditioner. New, we just moved into a mfg home. The air is really loud, is there a fix for this. Someone suggested we get a different squirrel cage...
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Theres all kind of answers.. close off the return grill and re route the return air system, get anouther unit, Have the realator to fix this problem or give you an adjustment, and you do it your self, ask a reputable ac man..ect, ect,,!
Posted on Sep 06, 2008
I HAVE A INTERTHERM NORDYNE E2EH-015H EVERYTHING WORKS GREAT BUT IS REALLY LOAD WHEN IT IS ON
It is probably a refrigerant copper line vibrating and touching the exterior cabinet or interior frame. It would have to be taken apart to move the copper line out of the way by a very small amount.
May 12, 2014 | Haier HWR12XCB Air conditioner
Vibration and loud rumbling noise
blower motor bad or squirrel cage out of balance.
Sep 30, 2013 | Gibson Intertherm Nordyne Miller Fan Motor...
Intertherm 2312 0r 2512 wiring diagram
http://enora.nordyne.com/Literature/Resarchive.asp#SP AC
Copy this link not sure why the Ac part at the end isn't attached to the link but it is part of it.
Should be able to find any wiring diagram for your Intertherm Ac, which is manufactured by Nordyne.
Hope this helps.
Feb 26, 2013 | Intertherm P3RA-048K Air Conditioner
Type of Flue pipe for Nordyne Intertherm mobile home gas furnace
The flue is just 1 pipe inside another, no insulation. But has lil support brackets holding the inner pipe in its place, centered to the outer pipe. I googled Nordyne Flue Pipe, and it is available online. And HELLO from the heart of Texas! Hope this helps!
Mar 12, 2017 | Heating & Cooling
I have a unit with a burnt transformer the original transformer has a red blue black on one side and a black with white stripes yellow and red on the other while the replacement has a green and red on one...
Hi, I have a suggestion here that might help. Contact the manufacturer to get an exact replacement sent to you. The manufacturer is Nordyne. Nordyne makes the same unit and private labels it for other companies, like Sears, Westinghouse, Intertherm, etc. Without out the correct color codes identifying the correct secondary (24Volt ) labeling of the wires the colors are meaningless. The colors of the original transformer wires are coded for the original Air Conditioning diagram that was packaged with it. The only standard coloring found on any transformer is for the primary side. i.e. 120 Volts 60 Hz Alternating Current. Those colors are Black for Hot and White for Neutral (or return).
If you get the transformer from Nordyne or a distributed for their products, Installing the new one will be very easy.
Here is the link to Nordyne
http://www.nordyne.com/web/ContactUs.aspx
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Intertherm P3RC-030K Air Conditioner
I have a Nordyne/Intertherm electric furnace #E2EH-012 in a mfg home I just moved into. The Handy Man removed a 16 x 20 x 1 filter (very dirty) from "somewhere". I'm not sure where a replacement filter...
The filter will go in to the backside (inside) of the cover with fins in it. There is a 1" (approx) bend (lip) there to hold filter in against backside of cover, in front of air vents. You may have to bend it slightly to get it in there but it will eventually fit in there snug. Incoming air will then be filtered as it is drawn through that filter, into blower area.
As far as fan switch goes, "auto mode" will be used when furnace is on, and fan will come on & off as necessary to dissipate heat as required. "Ventilate", should be basically same as "On", where the fan comes on to circulate the air throughout the home, just for airflow, and you control it manually.
So, when using furnace, have fan in "auto Mode".
Oct 10, 2010 | Heating & Cooling
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
I think I have the wrong air filter in electric furnace
Measure the width and length, then buy a filter that size.1" is correct for thickness.
The arrow points into the return. Not into the room.
Feb 18, 2009 | Intertherm P3RA-048K Air Conditioner
There is a hole somewhere in our outdoor coil on ac and it leaked out all freon. it is nordyne intertherm manufactured home ac. 1998 can it be fixed.
yes it can be fixed but you need to have the equipments like freon and the you need to fill the leakage thank you
Sep 03, 2008 | Heating & Cooling
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
