Connecting a reciever to an amps unswitched ac outlet
I am trying to turn everything on with one button.the back of my reciever says ac inlet is max 250 watts, i want to connect it to my amp that has an outlet that says unswitched max 200 watts. whats confusing me is this inlet/outlet thing,will it be safe to connect or shouldn't try it.
  • 10,594 Answers
Its safe to connect your receiver to amplifier's AC socket / outlet. These units has 2 type of AC sockets, Switched and Unswithced. Switched AC outlet can be On-Off by unit itself.
Feel free to ask any more question.
Posted on Sep 06, 2008
I have a Pioneer model CT-F2121 want to connect it to my Radio amp. I has two ports at back of Radio which is marked "switched" and "Unswitched" Radio is a Sansui model 210SS multi receiver. I have tried...
The deck if in working condition can be plugged into any AC wall outlet or the two AC outlets on the receiver. This is only for power, The Line outs and line in also have to be plugged into the Tape in and record out on the receiver as well. If the CT-F2121 need repairs that is what needs to be done first. Probably a whole set of belts.
Aug 12, 2013 | Pioneer Audio Players & Recorders
The remote control for my Zenith XBR413 is lost. Where can I find a replacement?
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Nov 05, 2012 | Zenith XBR413 DVD Player/Recorder and VCR...
I have an old zenith is4070. I am trying to figure out how many watts it pushes out to my speakers.
Model # IS 4070
Serial # W288209
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Jul 09, 2011 | Zenith Audio Players & Recorders
Unit will not turn on. All other components connected to the same outlet will. Is there a fuse in the AVR 125 that I need to check/change?
There is no mention of any fuse in the owners manual (downloadable from the link below)
You could try plugging an external device into the unswitched ac outlet on the rear panel to check if ac power is actually reaching the unit.
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR%20125%20OM%20FINAL%20(Rev.%204-3-02).pdf
Feb 27, 2011 | Harman Kardon AVR 125 Receiver
Touch screen wont work
Try the following to bring the touch screen backto life.
Step 1:
Do a power flee by unplugging the power cord from the rear of the printer and holding down the power button for 30 seconds.
If the above doesn't resolve the concern, then try the step 2.
Step 2:
Perform a Full Reset of the HP Photosmart ,
-Press the On button to turn off the unit.
-Disconnect the power cord from the back of the unit.
-Disconnect the power cord from the AC outlet.
-Connect the power cord to the back of the unit.
-Connect the power cord to the AC outlet.
-Press the On button to turn on the unit.
If the touch screen has not gone bad,the above troubleshooting steps should resolve the issue.
Thanks and regards,
Techbuddy247
Jun 10, 2010 | HP Photosmart D7260 Printer
120v plug in's on the back of my rx-v2400 will not send power to my mono block amps.
those are fused internally and made to power small items.the unswitched are constant power and the switched goes on and off with the power on the reciever.you have hooked it up to something that draws way to much power and more than likely blew the fuses.check the back by the sockets,they are rarely over 250 watts max.
Jun 12, 2009 | Yamaha RX-V2400 Receiver
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
How to turn on Kenwood KM-Z1 amp with SL16 input
Have you plugged the amp into the AV9000. Check if the outlet you are using is switched or unswitched. Changing the outlet will most likely do the trick.
Jan 12, 2008 | Audio Players & Recorders
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
635 people viewed this question
 Grubhead
Grubhead
