Question about SanDisk Sansa e250 MP3 Player
Recovery mode my sansa e250 2.0g is screwing up. i got it into recovry mode, now what do i do?
  • 2 more comments
  • Jaben Sep 11, 2008
    i tried this and media player recognises the device, the only prod is it says it only has 15mb of memory. also, i tried syncing a song to it and it didnt work
  • Jaben Sep 12, 2008
    how do i do that?
  • Jaben Sep 15, 2008
    only in media player when the device is in recovery mode
  • Jaben Oct 18, 2008
    it doesnt have a format option
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Sep 07, 2008
  • 1 more comment
  • Jean Sintulaire Sep 11, 2008
    What you will have to do is to format the device...Once you format it you should be fine...
    Let me know if you have additional questions...
  • Jean Sintulaire Sep 12, 2008
    Does the computer recognized your device?
  • Jean Sintulaire Oct 03, 2008
    try formatting the player using the player itself...to format the player using the player itself,,go to menu, setting and there should a format option..click on that and the player should start working back again..let me know if that doesnt work..
Sansa pmp recovery tool
The Sansa Connect Recovery Tool can be used to reformat and install firmware version 1.2.0.53385 to a Sansa Connect. This version is used in the current selling Sansa Connect products.
If for some reason device becomes unstable and resetting and erasing content doesn't resolve the issue, the Sansa Connect Recovery Tool would clean up your device and restore it to factory settings
2 things to check before starting the Recovery Mode and to use the Recovery Tool:
- First, charge the Sansa Connect for at least 20 minutes using the AC charger to ensure this is not a battery depletion problem.
- Second, hold the power button for 8-10 seconds to ensure the device is turned OFF.
After these steps, you can put the Sansa Connect into Recovery Mode and use the Recovery Tool.
Sep 16, 2012 | SanDisk Sansa e260 MP3 Player
REVOVERY DISC
hOW TO MAKE RECOVERY DISC
Step1 Insert a blank disc in to pc/laptop
Step2 go to backup and recovery
Step3 press create recovry disc
Step4 then it will be automatically make recovry disc
Step5 after completiton disc will automatically eject
ok
Mar 23, 2011 | Sony vaio vpceb32fm/w Notebook
Not getting started..
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Jul 02, 2010 | SanDisk Sansa e250 MP3 Player
My sansa e260 says load main screen fail switch to recovery mode...what do i do?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic go to /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa.
here is a link to a kid showing you how to go to recovery mode.
Usb mode in settings MSC is best, Updater recognizes it in this mode
Jun 26, 2010 | SanDisk Sansa e260 MP3 Player
I can't get the recovery disk on my acer apire m5641 to run. computer crashed and there's no more windows vista
a lot of acers have a seperate hard drive with recovry on it have you tried to see if the recovry is on there if not you would go to acer website and eneter your serial number and order new recovery disk get back to me
Oct 10, 2009 | Acer Aspire M5641 PC Desktop
Empty sansa 4gb mp3, no software on device
How to use the Sansa Recovery Tool for Sans Connect:
http://kb.sandisk.com/app/answers/detail/a_id/863/kw/RECOVERY/r_id/101834
Check
direct to the download Sansa Recovery Tool [66 MB]
direct to the download How To pdf file [420 kB]
Sep 22, 2009 | SanDisk Sansa Connect MP3 Player
It say's welcome to recovery mode first
download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Problems with Sansa e250 + Rockbox
Go to Sandisk's website and download the Sansa Recovery Tool
Jul 04, 2008 | SanDisk Sansa e260 MP3 Player
Psp recovery mode...anyone?
is your psp custom firmware'd? if it isn't then you can't go into a recovery menu.
Mar 24, 2008 | Sony PlayStation Portable (PSP) Console
Doesn't start
try resetting the unit. press down on the power/menu button for 15 seconds, and when the pinwheel turns off, wait ten seconds, the turn it on with the HOLD icon in place, and push and hold the record button while it turns on. this will usually bring you to the recovry mode. then you must plug your sandisk onto you rcomputer, and wait for it to tell you when to unplug it. I f this does not work, go to the store that you got it from, and tell them. They will usually happily replace it, but if they don't, then call sandisk, press four for MP3 SUPPORT, and talk to them about it.
Jun 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
