Question about GE Heating & Cooling
We set the temp to 64 with the decrease button and it immediatley goes back up to 86. the mode we have set to cool. we had it set to auto for awhile but that didn't work either. the temp just will not stay set where we put it. Help it's hot!
  • frances12 Sep 06, 2008
    Any assistants would be greately appreciated.
    Frances12
  • 958 Answers
Hello frances...
it could be that the display goes back to the room temperature ..you have set it already at 64... it is just going back to display the room temp..
tnx 4 using fixya.. drcool
Posted on Sep 06, 2008
    Guru:
  • 1,894 Answers
I think one of the two thermostats in your AC is malfunctioning
i would suggest you to test both of them
Haier a/c model esa408k-l mode is set on cool, speed set on high temp is 81 held temp button down, goes to 61 with in seconds goes back to 81.
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
Aug 26, 2015 | Haier Heating & Cooling
Digital temperature changes to 86 every time your set it to a lower temperature how do I fix this
If this set temp changes on its own then the circuit board has failed. Call a service tech or replace the unit. But this 86° might be the indoor temp, not the set temp? If I set my temp to 75°, then my temp goes to 86°, then the set temp (target temp) is 75° & actual room temp is 86°. The unit may not be working properly. Not sure if this helps.
Jun 13, 2015 | Haier Heating & Cooling
I have 2 zones, both of which are programmed. The display for zone 2 works fine. When I am looking at zone 1, the desired heating and cooling temps display as -- with no temps there. The system is set on...
Are these reading temps at 2 separate tstats or are you using temp sensors that send the temp back to the stat. It sounds like the sensor is not communicating with the stat.
Jun 14, 2017 | Carrier 38CKC042 Air Conditioner
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
I have a centrex air con.. and i dont know what to do the air is not cool.. and there no button in the remote that i could use and fix it..
In your remote, there is mode button, the symbols for each option will display. The symbols are:
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.To get proper cold air set temp 23 degree and mode"cool". To get heat set temp minimum 3 degree more than room temp and mode in "Heat"
Feb 02, 2011 | Heating & Cooling
At what outdoor temp does the unit stop heating. model lsn186he
Operating Range Cooling Operating Range: 23° - 115°F Cooling Operating Range with Low Ambient Kit: 0° - 115°F Heating Operating Range: 14° - 75°F Cooling Thermostat Range: 64° - 86°F Heating Thermostat Range: 60° - 86°F
Jan 08, 2011 | LG Heating & Cooling
Cooling has stopped in the upper refrigerator section. Frezzer section ok. Indicator says 64 degrees (upper). I push the button for temp and it says 36... then reverts back 15 seconds later to 64
Since the freezer is working the duct can be blocked . So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | GE PFS22SISSS Stainless Steel French Door...
My ac will not stay on when its at a certain temperture or auto. only if its in on position
this is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Jul 31, 2009 | Heating & Cooling
Samsung refrigerator RS2534WW ICE MAKER DOES NOT FUNCTION PROPERL
Hello here is how to fix the problem, first you have to remove the ice bin then then press the freeze temp and power cool buttons for about 12 seconds until the display panel switches to the option mode and you hear a beep.
A number under "Frige temp" corresponds to the option number. Press the fridge temp. button to increase the number and the power cool button to increase the number and the power cool button to decrease the number. set the option number to 3
now you have to select the input data to control the water supply time. Press the freeze temp button to increase the value. Press the power freeze bottom to decrease the value. Choose the right amount of water supplied to the ice tray which should be to where the water level is even with the rib on the inside of the tray.
input data = 00, 5 secs/01, 4 secs/02, 3 secs/ 03, 6 secs/ 04,7 secs/05,8secs
Let em know if this helps or not.
Nov 27, 2008 | Samsung RS2534 Side by Side Refrigerator
Sharp Z-830
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Nov 21, 2007 | Sharp AR-5316 Advanced Digital Imager...
Heating & Cooling Logo
196 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
