Question about Sony Cyber-shot DSC-W50 Digital Camera
Lens is stuck..help please!
I tried to turn my camera on and it said "turn the power on and off", i did that and nothing happened. I tapped on the lens and it worked. Then i turned my camera off again and it does not work and the lens is stuck. I tried pushing it back in and tapping on it but it didn't work. Any suggestions? Thank you.
  • 4 more comments
  • krystian617 Sep 11, 2008
    Hi guys,
    I got the same problem with this camera, but tipp on the lens doesn'T have any effect.
  • bmschau Sep 12, 2008
    My lens isn't still comes in and out but I have the same beep then the camera tells me to turn the power off then on again. Is there an easy fix that I can do myself?
  • deltuck Sep 18, 2008
    I have the same problem with the lens, "access", "turn off and on" sequence. Has anyone had any luck? Cost of repair? I'm about to buy a new camera but it won't be a Sony !
  • kalkii Sep 20, 2008
    I have the same problem. any one had luck fixing this? what's the cost of repair?
  • Anonymous Oct 05, 2008
    when i turn my camera on the lens goes out and then beeps and says 'turn power on and off again'  then the lens goes back in.
  • ccpanel May 11, 2010
    that turn-on/orr is not a solution. doesnt work. google your camera model for a solution. seems somtimes banging it helps, the other option is to completely tear it apart-i mean ALL THE WAY and move a spring then put it together.
    the best solution is to completly never buy sony, call customer service and complain and never buy sony.
    oh-the other most fun solution is to take it out back and use a shotgun.
  • 33 Answers
Use a shotgun.
Posted on Oct 06, 2008
    Problem Solver:
  • 6 Answers
I had the same problem and i know how to fix it all you have to do is pressing on and off non-stop..this happened to me yesterday. my friend ewas laying with it and it worked
all she did was press it on and off non stop like about 10 times or so
Posted on Oct 05, 2008
Camera turns on and says please turn camera off then on again, this is a never ending cycle have tried new battery etc etc, nothing works, also tried the tapping on carpet/table does nothing. please help...
The camera only says please turn off and then turn on again, when something serious is wrong. Could be a mechanical problem. like a lens that got stuck, but also when the camera can't access the memory. Please don't hurt your camera. Only when you know why and how to tap, it could help. But just tapping won't solve anything.
If the lens is really stuck, and you don't know what caused this, probably you can't solve this. When inside something broke, you can't solve this. Did you try to remove the battery for a little while and replacing it. Sometimes it can reset and forget a sensor is telling something is wrong. But really, if nothing helps, you only can get advice in a repair shop or with Panasonic.
Jan 04, 2014 | Panasonic Lumix DMC-LZ20
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
When i turn on my camera the lens trys to come out but then it gets stuck and goes back in; the screen says "turn the power off and on again" but when i do the same thing keeps happening over and over. The...
Here is a very reasonably priced quote for repair; https://www.teleplancamerarepair.com/quote/cart.asp?iProbID=5&mo=358
note; whatever you do, do not force the lens back in or pull it out. the alignment is off due to perhaps one of the barrels, or sliders, or even the internal rings around the lens. if anything "fell out" of the lens while you were tapping it around, be sure to send it in carefully wrapped for the repair.
Jul 16, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Last time I tried to turn on my camera (Samsung SL502) the lens came out but the screen didn't come on. I hit the power button again and nothing happened, now the lens is extended and won't go back...
Sounds like the lens mechanism is stuck - mine does the same thing after my 2 year old dropped it on the cement. Looking for a replacement lens now, but not having much luck. Read the previous posts for other solutions. Good luck!
May 28, 2010 | Samsung SL502 Digital Camera
I have a Sony Cybershot DSC-W30 camera. This morning, I took a picture of my daughter, and turned the camera off. Right when I was turning it off, she asked me if she could see the picture, so I quickly...
MY LENS IS ALSO STUCK OUT. I pressed on the lens by accident while it was on. Now it won't turn on and the lens is stuck out. I tried twisting it left as recommended by aplynn09 but didn't work. SOMEONE PLEASE HELP!!!
Jul 16, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Lens wont extend, lens error restart camera
My wife's Canon SD200 got stuck with an open lens and the E18 error. I opened the case and wiggled things and still nothing. Then, I turned the camera on and started tapping the edge of the lens casing with the magnifying glass I'd been using (need the battery and memory chip in place and make sure you've transferred pictures to your computer before trying this). Voila! The lens closed. But, of course, it wouldn't open and still gave the E18 error. Well, one good tap deserved another and Voila! again. It opened. After a few more iterations - and cleaning the lens casing each time, it was back to normal. The trick is the timing of the tapping. Just after turning on the power to the camera start tapping on the lens casing - not hard - just a light tapping. And don't tap on the glass lens itself -- you don't want to really break it.
May 15, 2009 | Canon PowerShot SD600 Digital Camera
Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Aug 12, 2008 | Samsung Digimax S600 Digital Camera
Camera wobn't turn on & lens stuck in out position
My camera stopped working during a wedding. The lens is stuch out, it will power on, but right after turning on, it beeps 3 times, then turns off.
Hope we find a solution!
May 14, 2008 | Samsung Digimax A7 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Restarting the camera
this would be because there is something stuck in the lens..could be the rubber protection stuck not enabling your lens to pop bback into position.i tried gently tapping the lens an gently twisting it to enable movement in my lens
Aug 13, 2006 | Canon PowerShot A420 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
41 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
