Question about KLH R7000 Receiver
Buzzing in KLH R7000
I have a shipping damaged KLH R7000 receiver that has a 60 hertz buzz in the speakers. The buzz does is always present and varies only slightly with the volume level. Everything works on the system. The repair shop said the trouble is related to a bad voltage requlator, which blows a capacitor that is supposed to filter out the buzz. They say that the voltage requlator would only be available from the manufacturer, and therefore would be very expensive. I don't work directly in the electronics field, but it seems to me that a voltage regulator would be a somewhat generic component that should be available from a number of sources.
  • 277 Answers
Look on the component for details or in the schematic of the device if u can find a voltage requlator that matches the same specifications as in ur system then u will b happy till then u will need the manufacturer requlator good luck windman
Posted on Feb 13, 2006
Manual for KLH R7000 receiver
Try Googling (KLH)(R7000)(manual) without parens.
Apr 23, 2017 | KLH Audio Players & Recorders
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Buzzing sound coming out of back speakers
Make/model of receiver or amplifier?
Type of speakers -
The buzzing is a 60 hertz ground loop - most likely.
Make sure all connections are properly grounded and that all connections are firmly in place. Assure that wires are connected correctly. If necessary, trace each wire to assure proper connection.
Older phonographs have ground connections. Most receivers have a ground lug nut connection.
Mar 27, 2009 | Audio Players & Recorders
Audio receiver!
When I watch movies, most of the talking is directed to the center speaker. During surround sound, this gives a more realistic environment, with voices coming from the source (center where your tv is) and ambeint noise coming from the left/right corners.
Get a small center speaker to solve your problem.
Jul 20, 2008 | KLH R7000 Receiver
Klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site,
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
Jun 15, 2008 | KLH R7000 Receiver
Technics sax-710 receiver Nht sb-1 speaker developed a buzzing sound when playing, Kids may have over drove speakers(not sure) Replaced with nht supezeros now both speakers sound very staticy like off...
The speakers have buzzing sound because of damaged cones.
Over driving speakers, especially with heavy low frequencies, can tear the voice coil away from the cone.
Once damaged, only replacement will help
Apr 24, 2008 | Audio Players & Recorders
KLH R7000 Component Video Problems
I have lost my remote and instruction book where? do is it worth it replace
Mar 07, 2008 | KLH R7000 Receiver
Klh r7000 no sound
go to this site Is under : KLH R7000 no audio repair. Problem solve
Oct 14, 2007 | KLH R3100 Receiver
KLH R7000 Receiver Logo
147 people viewed this question
Top KLH Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
