Question about Panasonic PT-53TW54 53" Rear Projection HDTV-Ready Television
No power outlet is working but can't turn tv on
  • Anonymous Dec 21, 2007
    I have a 10' Citizen tv. model#JCTV1582 that will not turn on. Their's power in the plug from the tv., but no power in the tv.
  • linbert Dec 21, 2007
    I have a 12 year old Citizen 12' tv.Model# JCTV1582. Their's no power when I turn it on. I've tried using the remote and I've tried turning it on by pushing the power button manually. Nothing happens. We tested the power cord from the tv. and it has power. If the problem is something simple @ inexpensive, we'll fix it. If not, it's to old. Before this happened, it was working great with a clear picture and good colours.
    Novelist:
    Champion:
  • 277 Answers
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
Posted on Nov 28, 2005
SOURCE:
Tv in bedroom not working but tv in living room working any suggestions
I am assuming it does not turn on. Did you try a different outlet that you know is working? If you know the outlet is working and the tv does not turn on or tries to turn on but does not then I believe the tv's power board has failed. If you use a remote, is the remote working? How old is the tv?
Jan 05, 2016 | Televison & Video
Coby tv wont turn on but has power
unplug it, hold power button for 30 seconds plug it in. does it work? if not test outlet. does outlet work? if so... tv needs repair
Feb 18, 2015 | Coby TFTV3225 32 in. LCD TV
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Can not turn on TV since power outage yesterday.
You may have to ensure that the power outlet is ok. Try the TV on another power outlet. If it does not work, the TV might need servicing.
Aug 25, 2012 | Vizio M221NV 22-Inch Full HD 1080P LED LCD...
Toshiba hooked to dish struck by lighting, will not turn on, solution?
Ensure the power outlet has power. Try TV on a different power outlet. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
Jul 28, 2012 | Sanyo Televison & Video
Tv won't turn on
Check for input power in outlet. Try connecting the TV to a different power outlet you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | RCA L22HD31 22 in. LCD HDTV
I bought LCD TV 32"
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Apr 03, 2011 | Televison & Video
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Panasonic PT-53TW54 53" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
