Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
Broadcast Fax Sending
Hi Guys,
I'm having transmission problems sending fax messages from WinFax to customers. I'm about to send flyers via fax to all possible clients (roughly around 1000 numbers) but 1 fax number takes 7~8 mins to finish. I'm sending 3 pages of flyer with a total of 500KB. We already tried to trim it down to 390KB but still the same rate of transmission.
My set-up consist of a Pentium 4 >2.0Ghz >1GB RAM Desktop PC, a residential line connected to a 56Kbps fax modem, and a WinFax Pro 10.03 fax software.
Please advise of steps and/or configuration changes to speed up the faxing.
I would greatly appreiate any comments and suggestions.
Best Regards,
  • 143 Answers
Change the resolution to STANDARD. This will cut your send times by 50%
Posted on May 30, 2009
When transmiting it connects ok it negotiate ok but at the trainning phase it disconnects, it receives perfectly. very strange
Try sending more then one fax to different recipients, otherwise it is not clear if the problem is specific to sending to one machine, or all fax machines. You also should post the type of fax modem you are using, if you are using a VoIP (Internet) telephone line, and the current settings in WinFax under Tools, Program Setup, Modems & Communications Devices. http://www.getfaxing.com/forums
Feb 17, 2011 | Symantec WinFax Pro for PC
On my activity report, under comment is states TX ECM I know the TX is transaction (I think?) what does ECM stand for
ECM (Error Correction Mode)
The Error Correction Mode (ECM) is a way for the fax machine to check the integrity of a fax transmission while it is in progress. ECM transmissions are possible only between machines that both have the ECM feature. If they do, you may send and receive fax messages that are continuously checked for their
integrity.
Sufficient memory must be available in your FAX/MFC for this feature to work.ECM (Error Correction Mode) Detects errors during fax transmission and resends the page(s) that had an error.
If you have Call Waiting, RingMaster, Voice Mail, an answering machine, alarm system or any other
custom feature on a single phone line with your fax machine, it may create a problem sending or
receiving fax data.
For Example:
Your Brother machine handles the Caller ID and Call Waiting/Caller ID subscriber services.
However, if you subscribe to only Call Waiting or some other custom service and its signal comes
through the line while your machine is sending or receiving a fax, the signal can temporarily interrupt
or disrupt the fax data. Brother's ECM feature should help overcome this problem. This condition
is related to the telephone system industry and is common to all devices that send and receive
information on a single, shared line with custom features. If avoiding a slight interruption is crucial
to your business, a separate line with no custom features is recommended.
Jan 20, 2011 | Brother IntelliFAX 2800 Laser Fax
MY WINFAX IS NOT CONNECTING TO SEND. THE LINE WORKS, I HEAR THE TONE DIALER DIALING, THEN THERE IS A LONG PAUSE WHILE "CONNECTING" MESSAGE APPEARS. THEN BRIEFLY THE MESSAGE DISPLAYS "NO CARRIER" AND CLOSES...
This is usually a line connection, or dialing problem. Are you sure the fax modem is connected to a working telephone line? are you sure your sending to a fax machine? Do you require any prefix (like a 9) to make an outgoing call? Are you dialing all the proper digits to make a call?
http://www.getfaxing.com/winfax
Feb 28, 2010 | Symantec WinFax Pro for PC
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
Winfax will not recieve
Unplug your fax machine. It's conflicting with your fax modem. If you have an All-In-One Fax , disconnect it from the telephone line.
Mar 23, 2009 | HP LaserJet 3500n Printer
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
Winfax sending issue,
What you describe appears to be a printer driver problem but cannot be sure , I'd suggest looking at : http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=413
Sep 19, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Winfax problem
I got the same thing. Cleared all temporary files on system, rebooted and VOILA!!! it worked again.
May 22, 2008 | Symantec WinFax Pro for PC
Winfax and Act! V6
Does this place answer any of your enquiries? http://www.fixya.com/support/p148729-symantec_winfax_pro_12_00_02592_pc
Aug 30, 2007 | Symantec WinFax Pro for PC
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
305 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
