Question about HP Computers & Internet
Just putting together a pc system, I've never done this before, and I assumed that first I'd connect the keyboard, mouse and monitor to the other bit and turn it on. The optical mouse now lights up and looks very much alive. The HP monitor (HPw1907v) gives me a message VGA Input No Input Signal Then it goes to sleep. The monitor is connected to the VGA socket on the back of the PC
  • Zaphod  Beeblebrox
    Zaphod Beeblebrox May 11, 2010
    ....do you have a separate video card installed ? Or are you trying to use your motherboards onboard video ? Some mainboards need to have a jumper set to direct the type of video output desired although most newer boards tend to utilize the BIOS for settings like that.
  • David Eisenberg
    David Eisenberg May 11, 2010
    What sounds do you hear when you power up the tower? Listen carefully & note the order of each.
    Sergeant:
    Champion:
  • 331 Answers
Check the jumper settting
or maybe your connection went wrong somewhere
just check them out
Posted on Sep 06, 2008
Will this pc work with a generic monitor/keyboard mouse combo
yes it should work, and if the machine were not malfunctioning, would he have brought it to you
Mar 07, 2013 | Computers & Internet
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Switch
KVM switch: This is a Keyboard video and mouse switch. It is used to connect multiple computer/servers to the same Keyboard Monitor and mouse. It is typically use in Racks housing multiple servers to swap between server without having to use a Keyboard Mouse and a Monitor per server.
SMC switch: I believe is a brand for Ethernet switches, used to connect computer together in the same LAN.
Nov 29, 2009 | SMC EZ Connect SMC2671W Wireless Network...
Where can i get windows vista driver for my tesco technika wireless mouse?
Below is a link to download Tesco's wireless mouse/keyboard drivers. It's a zip file so it will need to be opened and all files extracted before using. Tesco provides little information as to which what Operating Systems the drivers are for, just bundled them all together. Best of luck.
Greg
Tesco Wireless Mouse/Keyboard drivers
Nov 07, 2009 | Computers & Internet
Got a used Compaq Pressario SR1303wm and need to set up correctly
Monitor into Small Blue connector at back.
If Mouse and keyboard are Round and not Rectangular in shape then that's a PS/2 Mouse and keyboard. Purple goes into Keyboard slot at back. Green goes into Mouse at back. Watch for the design as the pins inside each one need to be inserted accordingly.
If they ARE rectangular then that is a USB connection. On the back connect the keyborad and mouse to the top two. Again, only going to insert one ways.
Jun 26, 2009 | HP Compaq Presario SR1303wm PC Desktop
No keyboard, mouse, or monitor
try to reinstall your memory card
Jun 18, 2009 | E-Machines eMachines Desktop PC
Microsoft Keyboard (1045) doesn't work with new Samsung Monitor
Hi
Keyboard and mouse have no connection with Monitor
Since keyboard and all are linked with mother board
so firstly i suggest you yo check the wireless connections are ok
Now reinstall the software packages that came with the keyboard(And drivers)
i hope this will help you
Mar 23, 2009 | Microsoft Wireless Notebook Optical Mouse...
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    Keyboard/mouse not working
    You need to restore to a previous date before you installed the wireless mouse / keyboard.
    If that dont work then your only solution is to format and reinstall since it might be you could have damaged a few vxd files window's needs to use those devices
    (THIS IS ASSUMING THE MOUSE AND KEYBOARD WERE CONNECTED PROPPERLY) AND THEN THE SYSTEM WAS TURNED ON
    if that wasnt done
    shut down compuer
    2.) plug mouse into green ps2 port and keyboard into the blue one
    3.) turn on computer
    Jan 03, 2008 | Computers & Internet
    Computers & Internet Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
