Question about Black & Decker CBG100 Electric Blades Grinder
Coffee Grinder CBG100 Black & Decker
Grinder does not run after running more than 30 seconds.It's dead.Is there any fuse that I need to change inside the grinder?Please send reply to www.brittany60156@yahoo.com.ROBERT
  • skezix1 Oct 26, 2008
    it just quit so I took it apart looking for a fuse inside. I found a soldered inline thermal looking link that had writing on it (d125 znwj ) and also 128 deg. C so I think when it overheats this burns out. I bypassed that link and it runs fine, but I haven't put a load on it yet so who knows? Need to find another link to solder in.
    A Meyer (ameyer1@verizon.net)
SOURCE: CBM205S - Black & Decker Coffee Grinder
make sure the top cover is depresed fully. There's a safety switch underneath it.
Posted on Nov 11, 2007
SOURCE: Black and Decker Dual Coffee Maker
it says 4 tablespoons per cup, but I use a heaping coffee scoop.
Posted on Jan 04, 2008
SOURCE: Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Posted on May 21, 2008
besneatte
  • 8 Answers
SOURCE: Black & Decker Coffee Maker DE755B--Thermal Fuse
Hi, the actual part you are talking about is not the heat fuse but the heat relay.
I have the same coffee pot, it 'died' on me and I was able to fix it. I actually had a bad relay AND a bad fuse. Here is what I did to get it working again WITHOUT purchasing any new parts and still keeping things SAFE.
Fist, unplug it! Remove the bottom cover ( you may need a special screwdriver for one of the screws, I had to file a notch in an old flat head ).
Unscrew the nut that connects the element to a bracket and to the plate. Remove the parts and set aside.
First thing you need to check is to see if it one ( or both ) of the actual fuses are burnt out. There is a wire that goes from the relay ( white ceramic cylinder ) to the heating element ( thick aluminum loop ), this wire has an extra sheath on it. Under this sheath there are 2 heat fuses in series. Check these fuses to see if one or both are burnt out. One of mine was. If both of yours are burnt out, you will need to order new ones ( see a post here ), if only one is out, you can do what I did. Using 2 pairs of needle nose pliers, I carefully loosened the crimping on both sides of the burnt out fuse and removed it. Using the same crimping I attached the remaining good fuse to the wire. Make sure you now have continuity from the output of the relay to the element.
The relay is the round ceramic thing with an aluminum "cap". It is attached to the heating element via a small black clip. Put an ohm meeter across this piece, if you have continuity, the contacts are probably welded shut, which is why your fuse blew. If not, the likely cause it, the contacts are burnt. Either way the fix is the same.
At the base of this relay there is a small lip. I used a small file to make this lip thin in one spot, then I carefully peeled it off all the way around. There is a crease right before the lip ( the part of the cap closest to the wires side of the relay ) and the lip peeled away nicely along this crease without damaging the cap itself. You can now remove the cap part and see the relay workings underneath. Be very careful when you remove the cap. Under the cap is a black piece of some kind of rubber with a tiny white piece of plastic in the middle. Don't lose these.
Now using an old toothbrush and some acetone clean the relay contacts and carefully free them if they are welded shut. Now use a small piece of fine sandpaper to clean up both of the contacts. Check the unit with a ohm meter, and if you have continuity, this part is done.
Now that you have peeled the lip off the relay, the pressure of the clip is required to hold it together. Carefully reassemble the relay ( don't forget the little white piece ) and while holding it together, against the spot on the element you removed it from, slide the clip on and back into place. Using the ohm meter again, check that every thing is connected as it should. With the switch on ( you DID unplug it, RIGHT? ) you should have continuity all the way from the plug to the heating element. If all is well put it back together and make some coffee.
I had some extra thermal grease laying around, so I cleaned of the old stuff and put some new on before reassembling ( where the element contacts the burner plate ). This probably not necessary, but not a bad idea either.
Posted on Aug 13, 2009
SOURCE: replacement carafe for Black & Decker ODC325N Spacemaker 12-Cup
You can have mine for the cost of shipping
Posted on Dec 04, 2009
Why when grinder is on finest setting
Did you clean the grinder before using it? Did you run a 1/2 kilo or so of junk beans through to clean out any oil/grease that was in the system from manufacture? How old are the coffee beans? If you grind at a 4 and run it through the drip machine, does the coffee still taste off?
Apr 30, 2014 | Mahlkoenig K 30 ES Grinder
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
The tip on one side of the grinder blade has broken off...the machine runs well and has not had a lot of use. Can the blade be replaced; if so, how, and how much? SmartGrind CBG5.
I have two different coffee grinders and if it is just the tip of one side of the blades you can continue using it, if there is a large portion that is broken I'm not sure of that model. Hint: check to see if the part is still in the grinder set the grinder for the most coarse grind, don't turn it on, shake it upside down to see if the broken potion is still in the grinder. If you find nothing use the grinder unless the performance is less than you like.
Feb 10, 2011 | Black & Decker Black and Decker CBG5...
I just want to know how to clean it after use - it is a coffee grinder, SmartGrind
How to Clean SmartGrind Blade Coffee Grinder - White
1. Always unplug the unit before cleaning. Wash the lid in warm, soapy water - not in a dishwasher.
Wipe the grinding bowl, base, and other parts with a slightly damp cloth or sponge. Take special care
around the blades; they are sharp! Dry parts thoroughly. Do not immerse grinding bowl, base or plug
in liquid or under running water.
2. Never use harsh detergents or abrasive cleansers or scouring pads to clean any
part.
3. To remove residue or aromas left behind by nuts, grind one tablespoon of baking
soda in the bowl then wipe thoroughly.
4. Use the built-in cord wrap on the underside of the unit to store the cord
Nov 04, 2010 | Black & Decker Black and Decker CBG5...
Saeco machine grinder
Due to the use the grinding burrs are slightly move and wire out. So I advice you to move only one max two step to more fine coffee grinding from the one you have and try the coffee.
The test you have to do is that for about 30 cc of coffee the time that the coffee will run should be about 20 to 22 seconds. If the coffee more faster you need more fine grinding. If the coffee run more slower than 28 sec you need more gross coffee grinding.
Good luck
Mar 23, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Oct 28, 2007 | Black & Decker (CBM205S) Electric Grinder
Black & Decker CBG100 Electric Blades Grinder Logo
96 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
