MPMan MP-F75 MP3 Player Logo
A
Anonymous Posted on Nov 27, 2005
Help my MPMAN!!!
Hi ,My mpman model MP-FOL7 is not starting up,I tried resetting, nothing.I also tried to look for firmware to reset also, nothing, any help will be appereicted.. thanks
Anonymous
Level 2:
  • Expert 513 Answers
  • Posted on Mar 02, 2006
Anonymous
Expert
Level 2:
Answers
513
Questions
Helped
596321
Points
826
If you couldn't find the firmware, here's a link - http://www.mpmaneurope.com/download.aspx?file_id=205 If the reset procedure suggested in the manual doesn't work, try taking out the battery for a day or two, that should also reset it. try switching the battery with another one. If it starts up when you connect it to the power cable then the battery or power supply system is at fault. If you still have a warranty, use it, if not, think how much a repair is worth for you and consult the shop you bought it with, or a similar shop that sells these products. Good luck
1helpful
Empty Disk
SAME THING HAPPENED ON MY MP3 I FORMATTED IT BUT IT WONT PLAY SONGS TRY FORMATTTIN IT USING WINDOW
1helpful
MPMan MP F35 T6
This player, oddly enough, only works with regular XP/SP1 - probably the only mp3 player in existence that is like that. I think the company's phrasing of the problem is quite humorous:
If you have WindowsXP SP2, we recommend that you go back to Windows XP SP1 before Microsoft solves the problem.
2answers
My mpman mp3 player not working
maybe you have loose connection! at the port connection! you can re solder it!
Blacked out screen
Have you been messing with the actual backlight, or with the backlight settings through the player? In case you haven't messed it up, you might be able to reset it by resetting the firmware, use this link http://mpmaneurope.net/download.aspx?file_id=163 Good luck ;]
Top MPMan Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a MPMan Audio Player and Recorder Expert? Answer questions, earn points and help others
