Question about Nikon Coolpix 5700 Digital Camera
The zoom only extended intermittently
Hi, The zoom only extended intermittently, then not at all."LensError" message permanant. Camera unusable. This problem occurred when turned on unintentionally, while in the case where zoom could not extend. The design of this camera left the switch very exposed with no locking mechanism to compensate. Therefore, a "zoom jam" is likely to happen. (This same thing happened the first time only 4 months after it's purchase, Nikon, itself, repaired it wth no charge. But even though I've been aware of this potential problem and handled it with care for 2 and 1/2 years, it happened again. Please check to see if Nikon has recognized it's culpability and will support this repair. I will do the same thing, but Nikon is notorious for it's non-response and may be more receptive to your inquiries.) Thankyou, Irene
  • 513 Answers
Its going to be hard for nikon to ever admit culpability over this problem, since many forms of miss use that is not an outcome of this specific design flaw may result in the same "LensError", which is a very common failure. Admitting culpability will cost them too much. This is not to say that it's not their fault... and if you go with your claim to a Nikon service center they might accept the truth of it, and atleast give you a discount on the repair, or offer better conditions on an upgrade. They don't have to, but once in a while you catch them in a good mood. Good luck!
Posted on Mar 02, 2006
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
I couldn't open the camera. when im trying to open it it shows and error message on screen "zoom did not operate correctly...."
Digital cameras with shutter covers sometimes jam, keeping teh cover from retracting and the lens from extending. That is what is giving you the message. You may be able to assist it by gently pushin it open when you turn on the camera. Key phase there is "gentle". Do not force it open as you may permanently damage it. If the motor is locked up or the lens cover still refuses to open, take it to a camera shop for service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Dec 23, 2014 | Cameras
Fix zoom error
The lens probably has some dirt or pocket fuzz caught in it. Try spraying around it with a can of compressed air when it is extended. Also spray the lens.
Oct 05, 2017 | Fuji FinePix S2000hd Digital Camera
E:61:00 on display window
Hi there:
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
• Turn the camera off
• Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
• Turn the camera on
• Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
• Lift the camera away from the hard surface and notice that the error message is gone.
• Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 20, 2012 | Sony Cyber-shot DSC-W110 Digital Camera
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
I am getting a message E18
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
In this link could check additional details: e18error.com
Hope helps (remember tp rate this answer).
Mar 29, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens will not retract
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse. Good luck!
Sep 11, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Super Zoom
In addition to the optical zoom, this camera is equipped with a super zoom and digital zoom for taking telephoto and wide-angle shots. The super zoom and digital zoom cannot be used at the same time. Super zoom is used to extend the optical zoom up to 14× magnification. However, the resolution is automatically fixed at 1600 ×1200. Digital Zoom is used to extend the maximum optical zoom to approximately 40x. However, pictures taken with the digital zoom may appear grainy. Camera shake is likely to occur at these higher magnifications, please see “camera shake” question for further details on this.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Super Zoom
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
57 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
