Can i put a new voice coil in the woofer of my JBL 4410?
  • 4,234 Answers
It is possible to recone this speaker. Get a recone kit from JBL. It takes a little practice, but reconing can be done. I have done hundreds over the years. Make sure that you get the kit from JBL. If you feel that you don't want to take a chance on this there are reconing shops around the country.
Dan
Posted on Sep 06, 2008
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
My JBL eon 15g2 speaker was working fine and then suddenly the lower woofer suddenly stopped. The higher tweeter still seems to work. All of the fuses are fine and all the wires seem to be properly...
the braided wires from the speaker connectors to the voice coil could be broken (from repetitive movement) or it could be the voice coil it self that could be cut open from a miss alignment of the cone (ware and tear), delicately push on the cone and feel if it rubs, a simple test is to check the IMPEDANCE of the speaker with a OHMMETER, if you have a reading (4,6,or 8 ohms) than the speaker is fine, check the rest of the wiring, if it reads OPEN than you need a new speaker...
Apr 09, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How to replace damaged subwoofer? Opened cabinet and found that the woofers' voice coil has burnt and the cone can't move. How to replace it the damaged speaker?
Since the coil is attached to to cone, you are looking at replacing the whole 15" driver (speaker)
To get access to the screws that hold it in place, you'll need to remove the front bezel from the cabinet, then remove the screws around the speaker's rim.
For what it's worth, that driver isn't a subwoofer, it's just a 15" driver. JBL does make 15" and 18" subwoofer drivers, but they aren't the same speaker as what's in this EON. Hopefully that will help you when you're shopping for a replacement driver.
Apr 10, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Hooking up the speakers
Well, this means you have dual voice coil subs. These subs are for running one sub in stereo mode( meaning you can hook up a right and a left channel to one speaker). In your case you are using 2 subs, which all you have to do is run a jumper wire from one side of the sub to the other. Take your (+) and hook it up on the (+)on one side of the sub and take your (-) and hook it up on the (-) on the other side and run a wire from the remaining post to the other. And do the same thing on the other sub.
Aug 09, 2009 | Blaupunkt Memphis MP66 CD Player
I am using Jbl 1200w woofer
actually i want tat d voice effect should b lik a surround system nd for tat i hv 2 increase d volume...by increasing the volume it gives a wonderful effect outside but m nt gettin ane vibrations inside ma car nd moreover i think thr is sm problem with vocals..shud i go 4 sm tweeters so tat sm clarity effect can b increased?..
Apr 09, 2009 | JBL BassPro Car Subwoofer
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
My magnet cracked on my jbl sub woofer can it be fixed
You might be able to get the manufacturer to replace it. Sub woofer repair is possible and some manufactures do offer that service, you'll have to check with them though. There is one other thing to consider- does it still work? If so you might be in luck. The magnet is there for its magnetic feild not how it looks. So if the magnetic field is un-affected and the voice coil is in one piece and un-obstructed it should be just fine. If the field is slighty out of place or not as strong it will probably affect its performance though. Good luck.
-Dynami
Mar 24, 2009 | JBL PB12 Subwoofer
Jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
Nov 02, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
62 people viewed this question
 Grubhead
Grubhead
