Pass key for a new laptop
I installed a new Dir-655 and it's working fine with my #1 laptop. later I bring a second laptop and then I got aware that i lost the pass key. I cant got it connected.
Thanks in advance RC
  • Jazric Sep 09, 2008
    Thanks I will try and let you know.
    President:
  • 2,961 Answers
Go to this site and download SIW (third one down in left freware list) and install it on the pc that already connects, it's aprogramme that allows you to see everthing listed on your pc including passwords.
when installed on the left column is secrets, click on this and you will see your router passkey listed, enter this key on your other pc.
Posted on Sep 08, 2008
How to remove a router security key from a DIR-655 D-link router?
Please follow the below steps to remove the security key from your wireless router DIR-655.
1. launch "Wireless Security Setup wizard". by clicking on setup.
2. Click "Next" , You will get a screen giving you an option to select the security level.
3. There you can select "None - No Security". & click on "Next & then click on "Save".
This would remove your security key from your wireless router.
Regards
Oct 11, 2010 | D-Link DIR-655 Wireless Router
I have the DIR-655. Poor coverage/Signal strength
What kind of construction surrounds your router? Weak signal indicates walls reducing signal strength. Try a repeater in weak areas.
Dec 30, 2017 | D-Link Xtreme N DIR-655 Wireless Router
My DIR 655 was working fine. Bot an IPOD Touch
Should be small recessed button on back of unit, use a pen and hold button in for about ten seconds to reset back to factory settings
Dec 28, 2009 | D-Link DIR-655 Wireless Router
Problem with DIR 655
On the laptops, check that your Internet is set to use "Private" networks as opposed to "Public". Private networks allow others to see you and you to see others on the network, once you've entered the proper pass phrase as set up in the router's software. Your Manual for the router has the instructions you need to complete this process.
Dec 15, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Forgot my wireless key...
visit http://192.168.0.1 or .1.1 to go to your router's page. (Make sure you are connected to the router while doing this)
From there, you can access your wireless settings!
Regards!
Jul 26, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can't connect to my K-jam to my new DLink DIR-655 wifi router
Can't connect to my K-jam to my new DLink DIR-655...
Mar 11, 2009 | i-mate K-JAM Cellular Phone
DIR-655 wireless intermittment - connections drop -
Any one with a mac ... MAKE SURE "Enable Auto Channel Scan : " is OFF.
CHANGE the name of the WIFI Network.
SET the Channel to CH11 [Others interfere with phone signals]
SET Security to WPA, TKIP Cypher, 3600. Then enter your password [min 8 all lowercase chrs] Change it when you are working.
Save and unplug the router and you will be fine.
Feb 08, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
