Question about Dell E173FP 17" LCD Monitor
Monitor will not turn on
PC works fine, tried on monitor on another pc..still does not work...will work every 4 or 5 days. It is an 18 month old gateway 19" flat
  • 3 more comments
  • jollyrr Sep 06, 2008
    Model P3902S will not turn on. My nephew had this monitor and gave it to me. It was working fine but when I got it home it will not come on. It is like there ie no power going to the monitor. Tried new cords and all. Still nothing.
  • billberty Oct 13, 2008
    i have a 20.10" iiyama prolite E511S but hoping for help, the monitor
    wont turn on, Ive plugged it in and turned it on but on standby, every
    time i press the power button, it flash's the desktop pitcher and goes
    back to standby.
  • jewelrygal4u Nov 08, 2008
    I have the same problem it wil flash from green to orange and will not turn on at all Can anyone help me!
  • duff557516 Nov 27, 2008
    monitor will not turn on. PC turns on but monitor will not. Power pluggin in and vga cable is hooked up. No sighns of power what so ever.
  • Anonymous Dec 20, 2008
    I have the same problem...
    Problem Solver:
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Cause of power goingoff: There is a bad 1000uF, 16V capon the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35Vcap for $2. This will work.
Why did the cap gobad? The cap is too close to a heatsink and over heated.
What does this capdo? This cap sends a signal to an ICwhich keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage isapplied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor:These monitors are difficult to open.
The two plastic pieces snap together and must be pried apartwith a flat screw driver.
After removing the stand, you need to insert a flat screwdriver at the bottom of the screen where two slots are located. Then work the screwdriver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuitboard.
Unplug the monitor cords from the driver board and removethe screen.
Unscrew the mounting screws from the power supply board andremove.
You will need to pinch the plastic support in the middle ofthe board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will beon the side of the cap. It will be bulged up on the top. You will see burnmarks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + ofthe cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from theheat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
I have a 20.10" iiyama prolite E511S but hoping for help, the monitor wont turn on, Ive plugged it in and turned it on but on standby, every time i press the power button, it flash's the desktop pitcher and goes back to standby.
Posted on Oct 13, 2008
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Display fails after a couple of seconds
Connecting a different computer that works to it doesn't fix the problem(what does that mean, its not CLEAR at all)
my guess is you meant the new PC fails on this bad monitor , too.
ok the monitor fails on PC #2, sure....
so the monitor is bad, why ask for help, buy a new monitor.
why spend $100 to fix it when new is %50
why>?
your not going to fix any monitor, here, on fixya,
but there is one thing to check the very old monitors from compaq
ive answered this 4 times here now.
has menu botton
see that? push that now on the monitor
see that menu..
? one menu selection , has silly horrible, power saver timer on it
and a RTC clock that keeps time of day, (pc can be OFF)
if the power saver is on , get it off now, and if paranoid set the clock.
id set it. so its double safe, see?
this happened back in 2002.
i read you users guide for you its a 2001. oops, its got the above BS.
read page 18 and all related pages to this. clock and saver.
page 18 there, page 16 real.
if it one , the INANE thing will go to saver at odd times.
later this was removed for VESA , update, remote sleep rules. and time.
https://www.manualslib.com/manual/30090/Compaq-Tft8030.html?page=18#manual
May 01, 2017 | Compaq TFT8020 (White) 18" LCD Monitor
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
Hard drive won't read monitor
that would be a video card unless the video is builtin to the mother board . either way they can fail
Dec 17, 2017 | HP Axiom 60GB for HP Pavillion n5xxx and...
Gateway MT6840 Laptop will not power up
Remove the battery, attach the power cord and try again.
Jan 15, 2009 | Gateway MT6840 Notebook
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
LCD Monitor - green power light blinking - nothing on monitor
Carol,
It sounds like your computer is putting the monitor in power save or sleep mode, and the monitor doesn't respond appropriately. The monitor might be faulty, or overheating. Make sure there is adequate ventilation around the monitor, and that it is clean and free from dust around the vents on the case.
Another thing to try is to check your computer's screen saver and power saving settings. Try turning off the "turn off monitor after [interval]" setting and see if the monitor still shuts off after several hours.
Good luck, hope this helps.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
My 4 month old laptop is not working
If the monitor turns black - maybe you have a screen saver or there is a fault with your display. Try using an alternative monitor or flat panel.
What do you mean by blockt?
Mar 12, 2008 | Computers & Internet
Dell E173FP 17" LCD Monitor Logo
192 people viewed this question
Alun Cox
