Quasar VM-L153 VHS-C Analog Camcorder
Problem for Quasar VM-L153 VHS-C Analog Camcorder
NO PICTURE
By PEANUT on Nov 26, 2005
WHEN I TURN ON MY CAMERA TO THE RECORDING MODE I DO NOT GET OR SEE A PICTURE IN THE VIEWFINDER OR ON THE LCD DISPLAY SCREEN,I DO SEE A PICTURE IN THE PLAY MODE.
Same Problem
Apr 28, 2009
-   when i turn ON my camera it's no display onview finder and LCD display (like in the dark room without nightshoot mode) but sometimes i press the photo button it's worked, mybe 1 or 2 secon-   kutuloncat99
Apr 22, 2009
-   I recently got my camcorder out of storage. It is working fine in playback mode but as soon as i switch to record the display screen and lcd go blank. All I get is a black screen. I have tried recording and it does record the sound but is not recieving the picture.-   missyk83
Jan 03, 2009
-   same here no pic on camera mode, playback mode is ok, grey screen green edges ,lines on it sometimes like picture is trying to come back.-   arceye
Jul 16, 2008
-   no picture on viewfinder or lcd screen but camcorder is working fine -   williamson15
Jul 02, 2008
-   I have the ZR 65 MC. When I turn the camera on to record, the screen is gray. I do get display information. It does work on playback. I changed the backup battery because I had the message to change it. I have gone through the manual many times to find out what is wrong.-   dcpar
Best Solution
posted on Oct 13, 2007
Very Helpful)
jdaugherty21
Rank: Apprentice
Rating: 100%, 1 votes
I can't believe it! My camera was doing the exact same thing and I read this solution and thought "Sure, take my camera and beat. Thanks for the help." Then I figured what could a little whack with a pencil hurt and the picture actually came back on!!!! I'm so happy. Thanks a million for this very simple fix.
Was this helpful?
Yes
No
Solution #2
posted on Aug 07, 2007
Helpful)
AceGoodBloke
Rank: Apprentice
Rating: 88%, 54 votes
I had this with my Panasonic NV-DS60. I thought it would be the ribbon cables not making good connections from the camera lens electronics because I had a similar problem with another camera. So I took the whole thing apart and disconnected and reconnected the ribbon cables - unfortuantely this didn't work! So I thought there may be another connection I couldn't see so I tapped around the lens area with a hard object (tip of a screwdriver) and it worked! It may be well worth you tapping the case in this way (without pulling the camcorder to bits) on the top, about an inch back from the front of the lens a couple of times. I'm not an expert, but it worked for me! Obviously, don't hit it hard enough to damage it. Good Luck
Was this helpful?
Yes
No
Solution #3
posted on Feb 13, 2006
Somewhat Helpful)
windman
Rank: Wiz
Rating: 77%, 892 votes
if u cannot record .... the problem is in the "mode" switch
if u can record, its a chip problem
Was this helpful?
Yes
No
Solution #4
posted on May 22, 2009
Not Rated)
becci_chuffa
Rank: Apprentice
Rating: 0%, 0 votes
i'm not in europe any longer so i could not take advantage of the free repair for the same problem on my mv600i, but me having no idea what I was doing decided to try what acegoodbloke tried. I unscrewwed the front section(lense section) after taking off that pannel I turned on my cam again to record mode and magically it was working,I carefully put the front panel back on and yep it still worked. I didnt even touch any cables or inner parts...so i'm just guessing its those cables at the front that are very touchy? stoked though, now i can sell it before its broke again :) never again am I wasting soo soo much money on something that decreases value as much as this camera did!
Was this helpful?
Yes
No
Solution #5
posted on Dec 24, 2008
Not Rated)
redbull7200
Rank: Apprentice
Rating: 0%, 0 votes
oh my god it worked for me as well i have a sony dcr pc101e and today i had the same problem and after reading this thread i tried to give it a few taps around the lens and it started to re gain a picture after one final firm tap it came on fully. thankyou for this advise it just made my xmas cos now i can record the kids on xmas morning. thankyou santa haha
Was this helpful?
Yes
No
Solution #6
posted on Dec 21, 2007
Not Rated)
jmjoseph
Rank: Apprentice
Rating: 0%, 0 votes
NV-DV65 every things ok but LCD diplay not display on record mode and playback mode View finder is ok
Was this helpful?
Yes
No
Solution #7
posted on May 24, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a sony handy cam DCR-HC42. When I turn on the camera I can see through the view finder, but if I open the screen there is no picture just a black screen on both the view finder and the screen. If I close the screen the picture appears back in the viewfinder.
Popular Solutions for Quasar VM-L153 VHS-C Analog
Questions and Unsolved Problems for Quasar VM-L153 VHS-C Analog
Do you recommend Quasar VM-L153 VHS-C Analog Camcorder?
Answer
Answer
Have a quasar camcorder. Battery won't hold charge. Replaced with a new battery. Did not fix the... (More)
Answer
i don't have a manual.- therefore don't know what up/far & down/near means - as well as how... (More)
Answer
My Quasar Palmcorder VHSC will not recored. I can not get anything to come up on the eye pice or... (More)
Answer
my quasar 700x palmcorder doesn't record or play sound. The picture is ok, just no sound. Help!
Answer
Please let me me know how I can obtain an owner's manual for the Quasa VM-153 VHS-C Analog... (More)
8 Other Users Have The Same Problem - Continued
Comment by mvg1, posted on Mar 16, 2008
WHEN ITURN ON MY CAMMERA TO RECORD THERE IS NO PICTURE ON THE LCD.
Comment by mariartz, posted on Jan 01, 2008
I have the exact same problem, please let me know of any solutions.
Comment by samsungtwo, posted on Nov 16, 2007
Have the same exact problem here. I'm afraid to do any tapping. Don't want any damage. I too can see what was recorded in play mode but this was from past recordings. I no longer can record. It only records a black screen and sound. What is going on???
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Quasar VM-L153 VHS-C Analog...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
