Question about AEG 23 in. Favorit 50750Vi Built-in Dishwasher
Remove bottom front panel AEG 6081
How do I remove the bottom front panel on an AEG 6081 Favorit dishwasher? The lower screws have a strange head - a philips head screwdriver doesn't work nor do allen keys - looks like the screw heads have been burred/damaged but they have never been touched before.
The upper screws on the bottom panel look ok but are obstructed by the door. Can't seem to get at them.
I want to get to the pump (I had a code 30 error) and I've read on the web thata common problem is a blockage in the pump.
Thanks
Norm
  • Anonymous Feb 02, 2009
    i need a pnc number number...help???
    President:
  • 1,462 Answers
Before you take the pump out, if drain hose goes into a spigot on the sink trap, take drain hose off and check hose and spigot are not blocked. this is very common.
can't remember anything special about the screws - used to be philips head but may have changed to multi-spline.the top ones are indeed obscured by the door panel but you can normally get to them with a stubby screwdriver or take the outer door panel off - just a few screws
Posted on Sep 06, 2008
Replace pump in aeg 74620
Remove the front panel. usually requires top off. powder tray out. and front lower drain/filter panel off. and then you can get to front panel screws front panel will still be attached by door seal sometimes there's enough movement to still get to pumps without removing it otherwise if you think you can get it back on remove that from the door lip and remove the front panel. the pumps are at the bottom left near where the pump filter door was. remove the relevant one. the recycler is attached to the pipe that goes straight back up to the top of the drum. the other is attached to the outlet pipe which heads off to the back of the cabinet
Mar 18, 2013 | AEG Lavamat 72640 Front Load Washer
How to remove top of door panel
often two screws which secure facia panel, access to these are usually from interia edges of door, covered by rubber bungs, careful thou, you may require more than two hands to remove and refit.
Feb 18, 2013 | AEG 24 in. Favorit 50740 Free-standing...
The door on my aeg 40850 dishwasher is jammed shut. How do I release the latch or remove the door?
remove the top two screws at back, lift up about 5 degrees pull back, then you wll see the latch pins remove bolt/s,lift up trim{if it has some} and the door will open then remove inner door screws to get the front panel off to get at the latch
Jun 30, 2012 | AEG 24 in. Favorit 40850 Free-standing...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
On off switch won't stay depressed on AEG dishwasher
Took unit apart and when I put it back it worked again. For how long who knows.
Access to the switch is difficult but by removing the printed circuit board, it seemed to allow the switch to work.
Dec 27, 2009 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Feb 02, 2009 | AEG 24 in. Favorit 3A Free-standing...
Aeg 88070im dishwasher
The machine must be opened and side pannels removed. Work on a table as all connections are visable once you have removed front bottom pannel and back bottom pannel. Remove the side pannels for easy access.
May 12, 2008 | AEG 23 in. Favorit 88070IM Built-in...
AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
1,897 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
