Question about Hitachi 53UWX10B 53" Rear Projection Television
Screen showss double picture
The screen suddenly shows double picture/words and discoloration throughout the picture
  • delkelso Sep 13, 2008
    same problem, double images, colors are not aligned correctly. for $650, think i will just buy an LCD...
I vacumed the dust inside the back of the tv. then noticed when i bumped the right lower circuit board the picture fixed. It later did the unfocused color thing again and i took a little rubber malet and tapped the circuit board a couple of times. It fixed again. My wife hits a sweet spot on that side of the tv and sometimes that fixes it too. I will eventually buy the kit to fix the problem for real.
Posted on Sep 16, 2008
  • 927 Answers
Good Day, cs81801;
It sounds like the TV's Convergence Circuit has failed.First, try
to reset TV by unplugging TV from A/C source, for 2 to 5 minutes. Then plug TV back into outlet. Also, try the Magic Focus button on front of TV.
Still no work? To fix yourself call 1-800-458-6053 and ask for KIT 10. This will provide you with all the parts you will need. These are soldered in parts, or call an Authorized Service Center and have them give you a written estimate b4 repairs are performed. Cost? between $450 to 650 depending on your location and Service Center. Good Luck, big IRISH.
Posted on Sep 06, 2008
The phone's picture shows lines and discoloration
May need to take it to cell phone repair mine looks the same way. Dropped it face down. Did your screen crack at all. Shouldn't be too much to repair it they quoted me $100.00. Hope this helps.
Mar 14, 2014 | ZTE Score
Plasma TV has a black uneven splotch in the middle of the screen
hmmm. sounds like the screen might be damaged. You might have to get a new one. But before you do that I would try leaving it off for a while maybe a few hours or so and see if that helps.
Jul 10, 2017 | Televison & Video
The bottom of the screen has an wave pattern of discoloration and shows double. The picture is very difficult to see at times.
your prism is off balance. it's like a shining a light into a mirror and point it into a specific spot. that mirror is out of sync, causing the image to move, which in your case it's a double image. the best way to fix this is to get a local repairman to fine tune your pic. again, the repair cost is between 200 to 400 bucks. just giving you heads up on that.
Oct 18, 2009 | Philips 46PP9302 46" Rear Projection...
My sony dsc-s700 digital camara
yes ccd is bad . replace ccd and will be like new.
Apr 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Discolored strips across top of screen.
If they are pink or blue stripes, I have seen this before. I hope the TV is less than two years old, because the optical block has to be replaced. The optical block has a two year warranty on the part, but you will have to pay labor. Just to double check, make sure you can see it on all inputs and also that it shows up on the menu and on screen display. If yes to all of these, it's the optical block and no adjustments will help. Be sure to rate this solution. Thanks!
Nov 08, 2008 | Sony KDF46E2000 46" Projection HDTV
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Red Screen/Download
if you have warranty for that phone you better take it back to the store you baught it from. it can be a very big danger hazzord if you dont
Aug 17, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Red screen with double picture
i have a Panasonic Projection HDTV pt-47wx49e and the picture comes in jumpy and very discolored is there any thing i can do to fix it.
Mar 28, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
105 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
