Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Will not crank
Craftsman model #050800B001660 serial #917270741 17hp intek ohv will not crank. Turn key and nothing. Checked fuse and checked 12v at fuse but dont know where to go next.
  • 1 more comment
  • Anonymous Sep 06, 2008
    i hear a click when i turn the key to start. even with a fully charged battery and a boost, I was able to move pulley by hand to make sure engine was not frozen, how do i check to see if its the starter or the solenoid? thank you
  • mowerless Apr 06, 2009
    I have a similar problem. When I turn the key to start my Craftsman YS4500, I get a few different results.
    1. Sometimes it seems like it tries to turn over but quickly dies
    2. Sometimes I hear a click when I turn the key to start
    3. Sometimes I hear nothing
    Can I jump the battery? If so, how?
  • mike kyle
    mike kyle May 11, 2010
    Check the starter itself. does it sound like anything is happening when you turn the key?
Sorry for not answering sooner but turns out it was the starter solenoid.
Posted on Sep 18, 2008
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
No 12v at starter
bad wire bad ground bad selinoid just work your way back
May 27, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman lawn tractor, LT2000, 18 HP OHV INTEK, 917.273752 I have a similar stalling problem as the one I reviewed in your forum, 10-15 minute run time, then stalls. Only difference, no cool down...
hi there
here is web site for manual and parts diagram
have the valves been adjusted correctly ? or could have a tight valve clearance
and when gets warm holds valve open - looses power
your engine will be 31p777 intek ohv avs
run the piston to tdc on compression stroke , then turn piston past tdc & set piston is 1/4 inch down the bore on power stroke this eliminates decomprssor lift from the setting
intake should be 0.003 Thou
and exhaust 0.005t thou
then check the carburettor main jets and emulsion tube and pilot jets and air bleeds and progression ports for obstruction etc for restriction / blockage
check fuel flow from tank to carb , check that the fuel solenoid has got continual 12 volt supply
when switched on and does not go o/c cutting fuel supply to main jet
have a look let me know
cheers hope it helps
pauly 46
dont forget the thumbs rating
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
22 hp B&S wont start
Disconnect and clean the battery termials and cables then reconnect the cables. Connection could be dirty. If that doesn't work make sure the battery has a full charge over 12v with a volt meter. If you have some jumper cables jump it from another battery.
Jan 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
582 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
